bit meter
bit meter
Does anyone know of an inexpensive bit meter plugin that will work with DP 4.6? Spectrafoo has one in their package but I don't want to spend that kind of money for the whole bundle - all I need is the bit meter.
Thanks,
Thanks,
- giles117
Yes Donate. $10.00 bucks is worth this bit meter. I have needed one and refused to buy SPectrafoo.
DP 6.02
Euphonix MC Control
Euphonix MC Control
Actually, now that I've used it a couple of times, it doesn't do the trick. Sometime all 32 indicators ar lit and it seems to be locked in that mode. Other times, every fourth indicator is out and all the others are lit. Other times it works fine...All on the same file!
If I can figure out how to get it to work properly I will be happy to donate.
- giles117
Havnt experienced that yet. Which version AU or VST??? I've tried both (under VST Wrapper)
DP 6.02
Euphonix MC Control
Euphonix MC Control
