menu tabs
Terry50
menu tabs
Post by Terry50 »
In the row of tabs (Tracks, Sequence, Drum, etc) near the top of the consolidated window, does DP9 allow you to edit these?
I would like to put a Event tab in the list and take some out that I never use.
Thank you,
Terry :unicorn:
Re: menu tabs
Cannot edit those. It kept me from using the CW for a long time. Now I just ignore them for the most part.
Re: menu tabs
You might consider using screensets. You could, for example, put a wide Event list in one of the sidebars, and save that as a screenset. Then remove the sidebar and save another screenset. Then you can switch back and forth to a screen with an Event list with one key entry.
With screensets covering most of the windows used, you can pretty much stop clicking on tabs.
