adding track selector to TO window DP 9.02
labman
Post by labman »
Ok, in 9.02, So I add track selector to TO inside consolidated window. (Yah !!!) And then I save a window set. Every time I recall that window set, the track selector is no where to be found and has to be put in there by hotkey again. Am I going nuts?
frankf
Re: adding track selector to TO window DP 9.02
Post by frankf »
The TO cannot have a Track Selector. Are you sure it isn't lurking behind another window?
Frank Ferrucci
http://www.ferruccimusic.com
Phil O
Post by Phil O »
The TO track selector window is working correctly for window sets on my system (if the track selector window is open when I save the set). But, I'm not using consolidated windows. Perhaps that's the issue.
Phil O
Post by Phil O »
frankf wrote:The TO cannot have a Track Selector.
It's new in 9.02.
labman
Post by labman »
Thanks Phil. Will research more.
Clarification. The track selector cannot reside in the TO window, but now can control content in the window. It has it's own window and can reside in the CW, but I do see it "disappearing" from that window from time to time and I have to re-open it. So yes, the TS does have a tendency to disappear in DP 9.02 (maybe in .01 as well , I'm not sure).
frankf
Post by frankf »
It's new in 9.02.
Thanks for letting me know. I'll going to have to check out the new view features.
Frank Ferrucci
labman
Post by labman »
MIDI Life Crisis wrote:Clarification. The track selector cannot reside in the TO window, but now can control content in the window. It has it's own window and can reside in the CW, but I do see it "disappearing" from that window from time to time and I have to re-open it. So yes, the TS does have a tendency to disappear in DP 9.02 (maybe in .01 as well , I'm not sure).
That is exactly what I am seeing MLC. It's there sometime, other times not so much. LOL
