MIDI editing totally screwed in DP 9(.01)?!
williemyers
Post by williemyers »
anybody seen *anything* like this??
if you check my post below, i tried using DP 9.02 and am getting constant crashing when trying to move MIDI data about in the TO. So I thought I would reinstall DP 9.01.
I've done that, and opened a new seq. with a single MIDI track. but, before even messing with adding a Kontakt Instrument, I thought I would try out just recording a few notes in to Bar 1 on that single MIDI track. I did that successfully but then, when I tried to drag the MIDI data in that track to Bar 5, it moved, but left (playing) duplicates of some of the original notes in Bar 1! That is, I originally played "C-E-G-E-G-E-C". And when I drug that block to Bar 5, it moved successfully, but left me with 3 x "E"'s in Bar 1!! And this is repeatable and happens in the TO and in the MIDI Editor!
Yikes! Anyone ever seen anything like this?
Back to DP8!
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
williemyers
Re: MIDI editing totally screwed in DP 9(.01)?!
o.k - - update - - stay with me here....
I have two bootable volumes on this MacPro - - a 10.8.5 vol and a 10.11.3 vol. prior to yesterday, I had DP 8.07 successfully running on both.
this morning, I purchased dp 9.01 and installed it on 10.8.5. I only played back a few old seq. (no editing). then this evening, I d/l'ed DP 9.02 and installed it on 10.8.5. then I opened a new seq. as outlined in my prev. post and the crash-on-MIDI-edit began. then, I reinstalled 9.01 on 10.8.5 and dulpicate notes on MIDI edit began.
then in reinstalled DP 8.07 on 10.8.5 and the dulpicate notes on MIDI edit has continued. I am fairly sure that, whatever in DP9 is messing with MIDI edit, was not wiped out when I reinstalled DP 8.07
the only relief here is that, throughout all of this, I still have DP 8/07 on 10.11.3 and it's remained untouched and works as it always has - perfectly. I would really like to get it (DP 8.07) back on 10.8.5, but I don't know if I'll ever get rid of the offending DP file(s).
any thoughts?
~me
williemyers
~me
