Tool Palette
ec_pat5150
Tool Palette
Post by ec_pat5150 »
it's been a while since i've used DP. I'm using the drum editor with Superior Drummer 2.0.
I cant' remember how to keep the tool palette open and accessible. The manual tells me to select "tools" under the studio menu, or to hold down "Shift+O". Both make the palette appear for a fraction of a second and then it disappears.
What can i do to make it appear long enough to make a selection?
MacBook Pro (Retina, 15-inch, Mid 2015) 2.2 GHz Intel Core i7, 16 GB 1600 MHz DDR3, Mac OS High Sierra 10.13.3, Apollo Twin Duo Thunderbolt, Digital Performer 10.11
stringtheory
Re: Tool Palette
Post by stringtheory »
that is strange - on my setup, those commands open the tools window and keep it open. no idea why it would not work that way for you. maybe mess around with the tools window prefs a bit, see if that changes anything. the "vertical tool palette" and "position tool palette automatically" prefs can be unpredictable, in my experience.
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
Re: Tool Palette
If nobody has responded to your posts in the other sections, you can delete them and save the moderators a bit of trouble.
Thanks.
