D.P. 9.02 dispo on MOTU Site
Re: D.P. 9.02 dispo on MOTU Site
I have not seen the splash screen since the update. Since DP 9.02 loads a lot faster, I don't miss it. Yes, the preference is checked.
Anyone try loading a movie into a project with a third party video interface yet?
I'm using a Blackmagic Mini Monitor via Thunderbolt, and I'm getting spinning beach balls. Even when I try to clear the movie window, DP freezes up. Not sure if I'm doing this right...
M2 Ultra Mac Studio (64GB RAM), 16" MacBook Pro (8 core 2.4 GHz i9, 32GB RAM, AMD Radeon Pro 5600M), Mac OS 14.6.1, MOTU DP 11.02, MachFive3.2.1, 828x, MTP AV, Roland XP-10, DJ-70, SH-101, MC-202, TB-303, RE-201, E-Mu Morpheus, Planet Earth, Moog Slim Phatty, Novation DrumStation, Oberheim OB-1, Yamaha 01V96v.2, DR-220, Casio PT-80, VL-1, SK-5, Focal CMS 50s
I get it every time since 9.02, and it had lately become intermittent!mikehalloran wrote:I have not seen the splash screen since the update. Since DP 9.02 loads a lot faster, I don't miss it. Yes, the preference is checked.
I'm on Yosemite, not El Cap, so there's a difference.
I just did three films in as many days in DP and updated DP during that process. I also reimported the video (24 fps .mov) in DP 9.02 and everything is going along swimmingly. I won't be moving from Yosemite in the foreseeable future. If this is my last OS, so be it, but it's working great and all the stuff I need to survive is working.RodneySauer wrote:Well, Rats.
I do a lot of scoring to video in DP. I upgraded to 9.02, and now in the two different projects I've tried, the movies don't display. The movie pane just shows black. What's more, if I double-click on the video pane (which is supposed to pull the movie out into its own window), the entire program freezes up. It even froze up the Finder, so I can't open and close folders or start the Time Machine program while DP is spinning its color wheel in the background.
This is grim. I guess I'll force-quit, and see if Time Machine can give me version 9.01 back.
(iMac i7, 32 Gbytes, OSX 10.11.3).
Rodney: what is your video format and fps? I'm using .mov @ 24fps and they're all working great. Do you have a third party video card or output device other than an attached computer screen?
However... not seeing the splash screen also means not seeing the plugs that are loading and I do miss that. Got the splash screen at first launch this morning.mikehalloran wrote:I have not seen the splash screen since the update. Since DP 9.02 loads a lot faster, I don't miss it. Yes, the preference is checked.
No need. Just install DP 9.01This is grim. I guess I'll force-quit, and see if Time Machine can give me version 9.01 back.
http://www.motu.com/download/download_m ... oduct_id=1
Or take a few minutes to re-export a test video and get back to us on your output hardware.mikehalloran wrote:No need. Just install DP 9.01This is grim. I guess I'll force-quit, and see if Time Machine can give me version 9.01 back.
As per Apple, repairing permissions is no longer necessary because new security features prevent them from being altered. Repair Permissions compares the current permissions with the BOM that lists what they should be. The BOM is provided by the software developer. So if Apple is correct, and the permissions do not match the BOM, it is because the installer did not write them correctly, or they provided an incorrect BOM.mikehalloran wrote:Do I really think it's necessary? Only for DP users—otherwise, not really. I don't think that Apple should have removed the API from Disk Utility but it is dead easy to copy and paste a line into Terminal — and wicked fast if you boot from an SSD.
On the other hand, perhaps installers use the BOM to write the permissions? I couldn't find anything to verify that. If this is what happens during installation, then Apple has it wrong, and permissions did change after installation.
Either way, the need to repair permissions has not gone away.
A picture is worth a thousand words they say. VSTi out is MIDI, virtual MIDI from the plug in. These are what's being relentlessly copied.musicman691 wrote:I'm a little confused - do you have two issues? I know you wrote about the tripling of MIDI entries earlier.Michael Canavan wrote:VST, AU as it stands doesn't send MIDI out from plug ins, this is needed with Maschine to set up Scene firing. ElCapitan, latest everything, except DP as of now.. I'll talk to MOTU tech about it, phone calls are quicker. It works really well in 9.01 BTW, and because AU is crippled this way it's something Logic cannot do.musicman691 wrote: Ouch. Are you using vst or au format plugins? And what version of OSX?
I think I'm in the minority on OSX in terms of using VSTi MIDI out with DP9, so I'm not surprised this bug got missed in testing.
Really? All of the plugins are there but, you are correct, I do not see them load without the splash screen.MIDI Life Crisis wrote:However... not seeing the splash screen also means not seeing the plugs that are loading and I do miss that. Got the splash screen at first launch this morning.mikehalloran wrote:I have not seen the splash screen since the update. Since DP 9.02 loads a lot faster, I don't miss it. Yes, the preference is checked.
The NAMM video may indicate, "Yes", but the NAMM press release clearly says, "No"musicman691 wrote:That's the way the NAMM videos seemed to say; the external hardware plugin routing deal is in the coming features category but SMPTE I thought was in 9.02.kwiz wrote:Isn't the new SMPTE plugin suppose to be in this update?
Availability
Workflow enhancements will be released in Digital Performer 9.02, to be released in Q1, 2016. The Next-gen Pre-gen engine, latency enhancements, SMPTE-Z plug-in and Hardware Insert plug-in will be released in a free update in Q2, 2016.
http://cdn-data.motu.com/marketing/motu ... 016-pr.pdf
[/quote]
Not seeing that but then again I don't have Maschine but I do have a lot of other NI stuff (Komplete 9). Do you have any way of trying this on a different OSX version? Could be an El Crapitan issue.
For fun I threw Geist, another VSTi that sends MIDI out and it also triples the input. <--- Sorry about that mistake earlier, it's the input selection for a MIDI track where 9.02 triples or more a VSTi, which makes sense in terms of it being an issue since that's what's different about a VSTi that can send MIDI out.
Trackspacer for instance in that list is not on a track that Maschine is on.
Doesn't let Maschine off the hook though, as NI have a Virtual MIDI input/output driver obviously, that shows up in the Input and Output list in DP whether Maschine is instantiated or not.
There are only a few VSTi's that output MIDI to the host, Reaktor can, so load an instance into a V-Rack and see if the VSTi repeated a couple times. I get three without Maschine loaded into the DP project. Also, when I delete the instrument, the repeats stay, I'm left with two Reaktors in my Input for a MIDI track. If I recall Reaktor into the instrument track I get more than three repeats(ghost inputs).musicman691 wrote: Not seeing that but then again I don't have Maschine but I do have a lot of other NI stuff (Komplete 9). Do you have any way of trying this on a different OSX version? Could be an El Crapitan issue.
I would definitely appreciate it if you loaded an instance of Reaktor 5 and let me know if you have the same issue. Curious to know if this is a bug on my system or a global one?
I've sent in a tech link to MOTU like a good end user.
Woohoo!! Separate background colors for audio and MIDI tracks in the SE are back!!
Formats vary from project to project; sometimes .mov, sometimes .mp4. Sometimes 24 fps, sometime 23.97, sometimes even 25 fps when working on European things. I've had this happen on everything I've tried so far. No special hardware: the video file sits on a hard drive (usually a different one from the project, which is different from the drive where the program lives). I use the video screen to make it show in DP, either in a pane of the consolidated window (when I'm working) or floating above (when I'm reviewing the work I've done).MIDI Life Crisis wrote:I just did three films in as many days in DP and updated DP during that process. I also reimported the video (24 fps .mov) in DP 9.02 and everything is going along swimmingly. I won't be moving from Yosemite in the foreseeable future. If this is my last OS, so be it, but it's working great and all the stuff I need to survive is working.
This last time I saw the first frame of the video, but it didn't advance when I told it to start. And then I got the spinning wheel of death, and the Force Quit Applications window says Digital Performer is "not responding." Maybe I'll try re-importing the video?
