What's the current state of VocAlign and DP?
- greg328
Need help with VocAlign in DP9!
I've installed the demo version of VocAlign 4.2.3, and it shows up as a AU plug available for insert on audio tracks, but the Vocalign menu commands can't find it. I see no VocAlign standalone app in my applications folder.
What's the procedure for using/loading VocAlign in DP9?
Greg
Greg
- greg328
Re: What's the current state of VocAlign and DP?
OK, I went the the SynchroArts website for assistance, they indicate only Vocalign Project 3 will work in DP, as a menu item, not Vocalign Pro 4.
It's still not showing up after install and trial license authorization.
Any idea if this software feature is even available in DP9? The menu items are present in DP9 but it continues to say it "can't find application".
Greg
Greg
I use vocalign project 3 with DP9.01 all the time.
You have to open Vocalign project application in order to allow comunication between DP and vocalign.
If you don't open vocalign project app and try to use the "built in Vocalign" inside DP, you get an error message, but if the application is running, you would be able to use it without a problem.
Hope I explained myself, my English is terrble!
Best.
Best.
8.07 64bit, Spire, Nexus, Fab FilterDiva, Gladiator, Nexus, Sylenth, Stylus RMX, Live 9, Reason 6.5, Komplete 8, AD Keys, AD Drums, Geist, Ivory, Waves 9 Mercury, Sound Toys, Fab, VEPro, Reason, Live, UAD2, x3 2408mk3, PCI424, MAC PRO Dual 3.46 Ghz 12 core Intel Xeon, Memory: 64gb ram, MAC OS X: 10.8.6
- greg328
I so appreciate your help! I wish I could find the standalone app, but I don't see it. I assume it installed in the applications folder. I'll do a complete system search again, but I don't think it installed the standalone. Where did yours install?
thanks so much!
Greg
Houston
thanks so much!
Greg
Houston
- greg328
I've scoured my hard drive, no sign of VocAlign Project 3 as a standalone app. The installer only installed the plug-in version, which is of course no use to me in DP9.
Anybody have any advice? I'll contact SynchroArts as well..
Best,
Greg
Best,
Greg
- bralston
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Brian Ralston
- greg328
Did not see that under the FAQ section on the SynchroArts website, I appreciate you sharing it. The only mention I found re: DP9 was that only Vocalign Project 3 would work as a standalone, not Vocalign Pro 4, which I suppose would run as an insert. ??
However, step 2 on the above tutorial is still impossible for me because I can't "run" Vocalign. The installer did not install a standalone app. So, not sure what's going on with that. I sent a help request email to SyncroArts today, hopefully they'll jump in with more info.
Best,
Greg
Best,
Greg
- cbergm7210
Works great here. And yes, you should see version 3.1.4 in your Applications folder:
http://www.rfjmusic.com
- Renaissance Man
Yes, I scoured my Mac for VocAlign3 but could not find it either. It apparently exists as a disc image. I ended up downloading a different version of VocAlign3 to make it work and keep an icon on the desktop to open the disc image.
Mac Pro Mid 2012 12-core 3.46GHz, 128GB RAM, Mojave, DP11, Waves Mercury & SSL 4000, VocAlign Project 3, Melodyne 5, EastWest Quantum Leap Pianos & Voices of Soul, Nomad Factory Integral Studio Pack, Slate Digital VCC, RC Tube & Trigger, & lots more plug-ins, MOTU PCIe 424, 3-2408Mk3's, 24io, MTP AV USB, Apogee AD-16X's & Big Ben, CraneSong HEDD 192, ATC monitors, tons of outboard gear & microphones, MIDI/keyboard rig, house drums & tuned percussion
www.nrpstudio.com
www.nrpstudio.com
