Alesis Micron - help with patchlist
mkrosen
Post by mkrosen »
Hello,
Can anyone point me in the right direction on how to set up the Alesis Micron in the audio MIDI setup so that it shows up in DP9?
Thank you for checking out my post.
Re: Alesis Micron - help with patchlist
The Micron itself just needs to be connected (drag and drop input / output ports) in AMS to reflect your real-world connections (MIDI cables to and from the unit) in order to show up in DP.
The patch-list required 'though (midnam file) is not installed as of DP8.07. I can't speak for v9.x, but I'm guessing you may have to hunt one down.
Unfortunately none of my Googled links is working right now, but you could try these:
https://www.google.com.au/url?q=http:// ... L3kEt6UwPg
https://www.google.com.au/url?q=http:// ... 12u_ES3u7g
https://www.google.com.au/url?q=https:/ ... 5mSykr19PA
You may have to define the unit in the Alesis middev file in order for it to appear in DP, but let's cross that bridge when we come to it. It's a simple procedure at any rate.
FWIMBW, these files will both reside here:
/Library/Audio/MIDI Devices/MOTU/Alesis
