Reaktor 6 and DP 9.0.1 loading issues.
David Polich
Post by David Polich »
For anyone who has purchased NI's Reaktor 6...if you own Razor (a Reaktor instrument), do not try to load it into Reaktor 6. It crashes DP immediately. If you have the latest version of Reaktor 5, you can load Razor without any issues.
I have sent a tech support inquiry to Native Instruments.
http://www.davepolich.com
musicman691
Re: Reaktor 6 and DP 9.0.1 loading issues.
Post by musicman691 »
David Polich wrote:For anyone who has purchased NI's Reaktor 6...if you own Razor (a Reaktor instrument), do not try to load it into Reaktor 6. It crashes DP immediately. If you have the latest version of Reaktor 5, you can load Razor without any issues.
Thanks for the heads-up on this. Was debating on getting R6 but seeing this I think I'll hold off for now. Been using Reaktor since it first came out.
musicman691
Is this the only ensemble you're having a problem with? Any others? Let me know and I'll ask over in the NI forums. Tend to get quicker answers from people who actually know and use the product. I've been down the road with NI support for a number of things and they tend to not be the sharpest knife in the drawer.
David Polich
I got an answer from Rocky at NI tech
support. He was able to reproduce the
problem. Yes, it only happens with Razor.
Rocky said he has notified the powers that
be about the need to fix the problem. He
also said that for the time being, the workaround
is to load the VST version of Reaktor6 and
loading Razor into that will not cause a crash.
musicman691
David Polich wrote:I got an answer from Rocky at NI tech
Good you got an answer this quick and that NI was able to repro the crash. Hopefully the fix will be soon.
