As usual, you're correctMIDI Life Crisis wrote:It can be done. Maybe mess with the movie start time? I don't remember exactly how to compensate for that and don't have DP running.
Setting the sequence start to -2fr is easy:PoliticalBonobo wrote:I basically need to set the sequence chunk time to -2 frames, but you can't do that. If I insert measures and start the sequence earlier, the start frame is always 00. Or am I missing something?
Thanks, that's what ended up working for me. Didn't realize the frames eventually looped around again.Rick Cornish wrote:Setting the sequence start to -2fr is easy:
23:59:59:28
I'm occasionally seeing 00:00:00:00 movie start times from young/inexperienced editors who never had to drive a tape-based system, which often puked on TC rollover. This is a good workaround for work-in-progress; but I'd encourage them to use a 01:00:00:00 start time for layback and mastering.PoliticalBonobo wrote:Thanks, that's what ended up working for me. Didn't realize the frames eventually looped around again.
