I found his while searching for an issue that may be related. I'll double post this so it shows up by itself as well.
I have noticed several times with DP8.07 on two different MBP, one an '08 running 10.9.5 the other a '14 running 10.10.4, sequences that play at incorrect speeds with no obvious reason. I have found that, for the first time in my experience with DP, DP can start up set at one sample rate while Audio MIDI can remain at another, not taking a cue from DP as it usually does, and always has in the past. This is always with Built In Output, no interfaces connected. It's a serious head scratcher when it does, since it's never to my knowledge ever been an issue.
HELP! Audio distorted on playback
Re: HELP! Audio distorted on playback
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
Bizarre, Doug.
It's as if DP's not telling the MIDI engine to compensate for the audio speed-up / slow-down, and it's instead rolling on in its own little world.
