MIDI Output Assignment Bug
ThomasDK
Post by ThomasDK »
There is a HUGE MIDI bug I found in DP 9.
Sometimes in the middle of a session - for no apparent reason that I can think of - DP 9 stops letting me route MIDI outputs. I open the session and everything works fine. Then around an hour or so in, when I click the MIDI output section on a MIDI track nothing happens... Nothing is greyed out or anything. Just nothing happens. No pop down menu, no nothing. When this happens I just have to quit out of DP and start the session over. This solves the problem until it randomly just starts happening again.
DP 8 doesn't do this - so I've switched back. I've been using DP since DP 4 and this has never been an issue for me. I hope this gets solved...
Mac Pro 2013, 32 GB RAM, OSX Yosemite
DP 9, MOTU 1248 + 828 mkII
LASS Strings, Omnispere 2, Waves, NI Komplete, Sound Toys, Reason, Izotope, VSL, 8dio, Softube, Scuffham, etc.
toodamnhip
Re: MIDI Output Assignment Bug
Post by toodamnhip »
I’ve seen this too, as have others. Sometimes multiple attempts resolves the issue, sometimes re starting DP etc.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
davidh
Post by davidh »
+1
I've reported this to MOTU and they are looking into it. Also pointed them to earlier thread here.
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
dix
Post by dix »
Uno mas.
I wouldn't characterize it as "huge" by any stretch. Easy to work around. Just restart DP. Still, I sure hope they squash it. Since it's intermittent it may be hard to diagnose.
Dwetmaster
Post by Dwetmaster »
+1
If your working on a big template and that it takes a while just reload the project, it IS a very annoying bug.
Sent from my iPad using Tapatalk HD
toodamnhip
As I reported in another thread, the “FIX” for this is to highlight a track or series of tracks and hit option and the “a” key.
This gives you the output assignment box and from there you can assign your MIDI. After doing this the 1st time, you probably can just click on the output of the track thereafter as it seems to fix the problem.
Good luck.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
dix
Post by dix »
Cool! It hasn't happened to me for several days, but I'll try this next time it does. Thanks!
yamguitar
Post by yamguitar »
+1, happened to me once as well. A quit and restart of DP resolved it at the time.
4 GHz Intel Core i7 iMac Retina 5K, 32GB RAM, OS 12.7.4 • MOTU M6 • DP 11.31, Reason 12.7.4, Dorico Elements 5.1
musicman691
Post by musicman691 »
Anybody getting random changes to the MIDI outputs when reopening a Project? Got a Techlink going on this one. It seems there might be a few issues with the MIDI output scheme.
