My tried and true muscle-memorized Command-Z and option-Command-Z undo and un-undo moves seem to be leading me into the wrong choices in DP9. Just realized this. Also, if I go to Undo History, the most recent choice to undo is a record track that is at least 3 to 5 actions previous to where I am; I don't believe this has to do with "Show One Branch At A Time."
Does anyone else notice this, or should I trash something, or just reinstall? I'd rather follow this through, rather than just reinstill, if it's been experienced by another moto-bro or motu-sis, as rare as they be!. Nothing's been lost as far as workwise.
DP9 - is Undo working differently in DP9 ??
- tommymandel
Re: DP9 - is Undo working differently in DP9 ??
It's been mentioned here multiple times that the undo function key codes have changed in DP9 - now it's more like every other computer program (just like track selection in the Sequence Editor is now like every other program). It's also been mentioned here that it's possible to change it back but that I don't know how to do; I like it the way it is now.
I think you meant key commands, not key codes (although they changed as well).
Yes; got my words mixed up.MIDI Life Crisis wrote:I think you meant key commands, not key codes (although they changed as well).
- tommymandel
Thanks guys. I'm sorry I didn't do a search first - I've just not been that fruitful the times I've searched for issues here. Too many returns, and too many results were just different posts to the same original post.
Much appreciated.
Much appreciated.
