Changing presets but keeping fx used
Rockshamrover
Post by Rockshamrover »
Hi folks,
I'm just wondering if it's possible to do the following.
I load up a preset, lets say an EP and I add an arp and some reverb etc. I like what the arp and reverb are doing and i want to change the preset instrument, but keep my FX. Is this possible?
http://soundcloud.com/rockshamrover" onclick="window.open(this.href);return false;
Born to run, but mostly walk.
Re: Changing presets but keeping fx used
Save the presets as a preset group (forgot what that's called).. You can call up that specifying grouping of presets. I think it's a drop down on the top right of the mixer menu and probably a control-click on the preset name in the list.
Rockshamrover
Thanks MLC, I think I figured it out :)
I tried the "load as layers" thing at the bottom of the main screen, so it lets me have multiple versions of presets for the same instrument, I can then have the same fx on each. Mute the ones I don't like etc.
It's a bit long winded, but it's working :)
I'm on my machine now. At the top of your inserts there's a gray box. Select SAVE INSERT SETTINGS.
Then when you want to call up that setup, hit the gray box again and the saved insert (which you can and should give a name to or it defaults to a lucg name) will appear in the center drop down menu.
THAT is how you do it.
Rockshamrover
That's excellent :)
Thank you very much.
Don't that me. Thank MOTU. Ok, you can thank me. :)
You're welcome.
Rockshamrover
:woohoo:
That'll do! :) :unicorn:
