DP9's new Undo/Redo behavior
hammerman
Post by hammerman »
Just a heads up that Command+Z does not toggle the undo/redo anymore. The new behavior is unlimited Undo and Shift+Command+Z will Redo everything. From the changelog:
• Removed Undo/Redo from the Edit menu, replacing it with unlimited undo and redo as separate commands. Undo/Redo is still available as a command but has no default binding.
You CAN go back to the old way as Undo/Redo is still there in the Commands window - assign that to Command+Z and change good ol' Undo to something else.
I'm living dangerously and trying the new way as it is more Mac-like.
Over and out.
SMS
Re: DP9's new Undo/Redo behavior
Post by SMS »
I like this.
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
mocker
Post by mocker »
Great ! Finally.
musicman691
Post by musicman691 »
I'm loving the new features like this; makes working in DP a lot simpler and like other programs. Now I don't have to stop and think how does DP do this differently than other programs?
Robert Randolph
Post by Robert Randolph »
musicman691 wrote:I'm loving the new features like this; makes working in DP a lot simpler and like other programs. Now I don't have to stop and think how does DP do this differently than other programs?
This is a great point, and why I'm happy with the feature.
I have DP open ~6-10 hours a day, and with DP8 I'd still wake up the next morning and use undo incorrectly the first couple times before remembering I had to hit option for it to work like every other program in OS X.
This new way is way, way, better.
hammerman
Post by hammerman »
I'm liking this new behavior. And isn't it great that MOTU gives us the option to assign a key command to Undo/Redo if we want that option as well? We have our cake and we can eat it as well!
Morpheo
Post by Morpheo »
Indeed. Speically when you're used to one particular "other program" :wink:
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
musicman691
I'm NOT talking about one particular 'other program' where I assume you're talking about ProTools but just about every other Mac program has undo like DP9 now has.
Morpheo
Post by Morpheo »
musicman691 wrote: I'm NOT talking about one particular 'other program' where I assume you're talking about ProTools but just about every other Mac program has undo like DP9 now has.
I know... was just joking.
(although I did had some adjusting to do when I switched back to DP "full time" a few months ago)
You know, all you had to do in DP 8 was change the key command.
musicman691
You're not the only one my friend :)
mhschmieder
Post by mhschmieder »
What I have wanted more than anything over the years, is Undo/Redo in the Mixer window, as it's so easy to make a mistake and/or not see where mouse focus is and not be able to return to that "perfect" mix setting.
For starts, the knobs/etc., if not also the plug-ins and inserts and their controls/settings.
Did the split of Undo/Redo in DP9 also increase its coverage across the app to previously excluded parts of the app, like the Mixer window?
Mixer operations don't appear in the Undo history and aren't affected by the Undo command. If you do arrive at "perfect" mix, you can alway duplicate it and work on the copy, and leave the perfect version intact. You can assign a key command to Duplicate Mix, so it's not that much of a bother.
toodamnhip
Post by toodamnhip »
mhschmieder wrote:What I have wanted more than anything over the years, is Undo/Redo in the Mixer window, as it's so easy to make a mistake and/or not see where mouse focus is and not be able to return to that "perfect" mix setting.
That’s why I lock my mixes with automation asap. However, doing so leads me to other bugs with Dp’s automation. Its a trade off but I go through great pains to automate everything possible.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
BKK-OZ
Post by BKK-OZ »
I agree about the lack of mixer window undo being a pain. Yes, you can lock a mix, yes you can use automation, but why the hell can't you just simply undo?
Cheers,
BK
- M Kaku
