How do you create legato in MIDI Editor
Hi
I'm looking for a simple solution to this common problem: I record a MIDI track that is routed to a VSL Flute. To make the sound legato there have to be an overlap between the notes, but I don't always accomplish that when I play the notes. So is there a way to select the notes in the MIDI editor and have DP8 checking to see if the notes overlap and if not extend the notes a bit to create the legato?
Mac Studio Max 64 gb, PC server 64 gb, MacPro 12 core 48 gb.
DP 11, Pro Tools 11, Logic 10, Cubase 11, Studio One 5... Waves9, All NI, All VSL, LASS 2, Brodway Big Band, UA I & II, Altiverb 7, Arturia Synths, BFD3, Sound Toys, All Toontrack, Ozone, Melodyne, Spectrasonics, UHE.....AND a Steinway Concert Grand model A.
Re: How do you create legato in MIDI Editor
One way: Use the "move releases to closest attack" command. Then use the duration command to make the notes a few ticks longer to get the overlap.
Man...after all of these years, I wish they had something like that built-in!
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.03, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro
+1bayswater wrote:One way: Use the "move releases to closest attack" command. Then use the duration command to make the notes a few ticks longer to get the overlap.
DP 10.13, OS 13.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
? It is built in. It's in the Region menu.JSmith1234567 wrote:Man...after all of these years, I wish they had something like that built-in!
I meant a force-legato command.
How would that differ from the existing Region menu command? Or are you talking about something that would record a passage as legato in the first place?JSmith1234567 wrote:I meant a force-legato command.
