DP & M-Audio O2
DP & M-Audio O2
I am running 4.6.1 on 10.4.3. The O2 shows up fine in Audio MIDI Setup and works with Reason, but the input for the O2 does not show up in DP.
Has anyone had any luck getting DP and the O2 to work?
- kelldammit
- Primary DAW OS: Windows
- kelldammit
- toofar
hmmm... Does it show up in the MIDI Monitor window and show activity? It should at least be grayed out there if it's in AMS.
Also, are you using USB or MIDI cable, and have you tried the other if the O2 has that option? I know that with my PCR controller, USB was not very dependable, but running it MIDI is very solid. OTOH, my M-Audio Trigger Finger runs USB and there's no problem whatsoever. Keep us posted.
Bill
Bill
iMac 3.2GHz 6-core i7 & Mojave | Audient iD14 | DP 10.0.1 | MIDI Express XT | G4 dual 1 ghz MDD & Tiger | 2408 mk3 (x2) | A-500 PRO | Rosetta 200 | Toft ATC-2 | Mackie VLZ3 | JBLs | DP 4.6 | Live | 'n stuff
