Slate Plugs Crashing DP Upon Opening
Anyone else having this happen with recent updates for VCC, VBC, or VTM?
Only work-around for me so far: If I reboot 'puter and repair permissions and keep trying (3 or 4 times); DP will finally open, then I remove the Slate plugs from channel inserts and then re-insert plugs—everything's cool and stays that way next time I open project. Unfortunately, I lose the settings on the plugs which gets messy when I have a lot of instances. Kevin at Slate told me they don't test on DP. I took that info politely and said "Thanks, it's OK—I'll get some help at MOTUNATION."
DP 10.13 / OSX 10.14.6
MacPro 3.33 6-Core w/SSD, 32G RAM. Metric Halo I/O. (...using MH Console as a summing mixer.)
VIs / plug-ins include NI Komplete, VSL, Slate, Sound Toys, Voxengo, Kush, Eventide, Oeksound, Izotope.
Re: Slate Plugs Crashing DP Upon Opening
I'd find the preferences and settings for the plug and trash them.
I should have said, "MLC" will save me... again. I'll give that a go. Thanks.
I don't know it'll work but it sure sounds like a bad preference if it's ok until quitting.
I'll give you an update in a few hours. Thanks!
Thanks MLC, the preferences were not the issue, according to Paul at Slate support. He advised the manual un-install / install with the extra steps listed here—seems to have cleared things up! The issue was not with VCC. Italics mine.
Remove Virtual Buss Compressors and Virtual Tape Machines from the following plugin paths:
HD/Library/Audio/Plugins/Components/
HD/Library/Audio/Plugins/VST/Slate Digital
HD/Library/Audio/Plugins/VST3/Slate Digital
HD/Library/Application Support/Avid/Audio/Plugins/Slate Digital
HD/Library/Application Support/Digidesign/Plugins/Slate Digital
Delete Settings File:
HD/Library/Application Support/Slate Digital/
Repair Disk Permissions
Restart your computer.
Install latest plugin builds (Get 'em from the Slate website):
VBC 1.2.5.9 Mac Installer
VTM 1.1.8.20 Mac Installer
See Release Notes
Please ensure permissions are set to "read and write" for the following location:
Be sure to "apply changes to enclosed items in pull down menu at bottom. (Unlock, first!)
Next, delete the AU Cache file found in User/Library/Caches. (I couldn't locate this, folks—yes, I did the Option tab under the Go pull down—but didn't matter.)
I
See Release Notes
I
- corbo-billy
Thank you for the return because it has happened sometimes at home .
