Audio Wire
larbok
Audio Wire
Post by larbok »
Hi,
Is there any difference between the Audio wire used on the 2408Mk2 and the 2408Mk3?
Thanks you!
LARRY BROCKWAY
HALL OF FAME STUDIO
Mac Pro Quad 2.8 w/8gb Ram
IZ Radar 24
DP 8.1
Motu 2408 Mk3
Motu 2408 Mk2
MIDI Timepiece AV
Motu MIDI Express XT
Soundcraft 6000 52x24x2
Re: Audio Wire
If you are trying to make a FW-400 cable work or are trying to figure out which cable in the box is the AudioWire, this may help.
The original AW cable has a slightly different connector than a FireWire cable. Peeling back the insulation on a FW connector about 3/16" generally works. Use an Xacto knife, single edged razor blade or similar tool.
I have only owned a 1st gen 2408 -- these predate FireWire, BTW. If MOTU changed connectors on the later versions so that an FW cable just works, I have never heard.
Re: Audio Wire
All AudioWire cables are the same; I've used the system since the 2408mkI and there's been no change AFAICT.
JeffB
Re: Audio Wire
Post by JeffB »
I've always used firewire cables with no problems.
Studio: i7 4770K, 32Gb DDR3, W8.1 x64, PCIe424, 2408Mk3.
Stage: Lenovo W530 i7 3720QM, 16Gb DDR3, W7 x64.VS700R.
Re: Audio Wire
JeffB wrote:I've always used firewire cables with no problems.
That works for many. For others, it doesn't work without modification of the connectors.
