mhschmieder wrote:Are you certain about that, Carlos? I thought it was an issue a few years ago, until I noticed it had to do with offsets more than 9.9 dB, where you lose one decimal place of precision. It seems DP stores the same resolution but doesn't display it at that point, so it remembers the original offset if you then move back across the magic 10.0 dB marker.
I started using trim plug-ins to avoid ever having to attenuate a track by more than 9 dB or so during stem mixing.
Yes. Basically it comes down to this as far as I can tell. If you try to nudge up your grouped faders beyond the point they were at when the group was initially created the relative level offsets between them start to compress. Lowering levels doesn't seem to present the problem.
So, if your nudging faders to try and find the sweet spot of some drum channels say, before you have written automation, this becomes an issue. Especially if the individual channels are not being routed to a common output where a group fader could be used.
Carlos
