Frequent Crashes
RobTalbert
Frequent Crashes
Post by RobTalbert »
I am running DP 8.07 under OS X 10.9.5 on an older iMac 4GB 2.4 GHz Intel Core 2 Duo. I have a couple of instances of MachFive3 running software instruments. I run okay for half an hour or so, and then I start having crashes where DP shuts down. If I reboot the computer and restart DP I can run for another short while until the next crash. I suspect MachFive as the main problem, but I'm really not certain about that.
I have all other programs including time machine and background processes turned off. I'm thinking I might just need a new machine. The new iMacs with faster processors and more memory look inviting. Would this likely solve my problem? Any issues with DP or MachFive3 running under the newest Apple OS?
Rob Talbert
Maryland
iMac M1 with 16 GB RAM, OS X 12, DP 11, Focusrite Scarlett 18i20, Waves Plugins, Melodyne, Kontakt, BLUE Kiwi and Neuman Mics & BLUE Robbie Pre; Martin D18, Martin OM25, Cordoba, & PRS CE24 Guitars.
Re: Frequent Crashes
Around here, I don't think that machine is THAT old. However, you might be running out of RAM.
How about machfive in standalone? If you disable M5 is DP more reliable?
apanacci
Post by apanacci »
I have posted before that MachV does not play nice with other virtual instruments. Try working without it or only with it and see if that works.
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
