I feel like I'm losing my mind! I swear there was a feature where you could click an insert slot on an aux, and then add certain plugins to a "favorites" list. And then if you go back and right click on an insert slot, it ONLY shows your favorites. For me, it just shows a full menu of all vendors and their plugins. I've tried searching through the manual but can't seem to find the right keywords to look for.
Digital high-five to anyone who can help refresh my memory..
Effects plugin "favorites" list?
Re: Effects plugin "favorites" list?
Maybe you're thinking of the User Category feature in the Effects tab of Plugin selection window. If you put your favourites in a new category you can set the window to show that category by default.
Or maybe you're thinking of presets. When you save one, it appears in a list at the bottom of the presets drop down menu.
I believe you're thinking of a user preset. Here's how you do it:
Insert something on the first insert effect slot on a track.
Insert something on the second insert effect slot on the same track.
Insert something on the third insert effect slot on the same track, etc., until you have
filled all the slots you want to fill.
Now look at the field with the little downward arrow directly above the first insert slot.
Click on the arrow. The first option in the drop-down menu is "Save Insert Settings".
Select that option, then type in the name of your insert effects "rack"…for example, "Female
vox". Click Ok.
The next time you click on the field with the arrow to reveal the drop-down menu, you will see your newly-saved preset listed.
vox". Click Ok.
http://www.davepolich.com
Aha! Go to the effects chooser, choose "Effects" (not Presets), make a new category called "Favorites" or whatever, add stuff to it, then right click that category and choose "Save As Menu Category." Now when you right-click an insert slot, it shows ONLY the items in your favorites. I knew there was something I was missing.
There you go. That's what I do, except I have hundreds of favourites.MDesigner wrote:Aha! Go to the effects chooser, choose "Effects" (not Presets), make a new category called "Favorites" or whatever, add stuff to it, then right click that category and choose "Save As Menu Category." Now when you right-click an insert slot, it shows ONLY the items in your favorites. I knew there was something I was missing.
