Yosemite
Re: Yosemite
Am I right in thinking that Time Machine has changed? My ML partition created a TM file that was an image file on my backup drive. The Yosemite partition version of TM added to this backup, but the whole thing changed to set of conventional folders for each backup date and time. Both partitions can see this backup set and display it in the expected way.
- Steve Steele
Re: Yosemite
Yes. But it's temporary. I always check kexts before installing a major update. ML broke a few of them. Apple put in a new security feature for Kexts. Most of them shouldn't be a problem though.bayswater wrote:Just to make sure I understand, does that Terminal command turn off all the kext checking at Startup?mikehalloran wrote:Since Soundflower and Jack (like Trim Enabler) work by going around the Apple Toolkit, it will be interesting to see if Yosemite compliant versions can be developed.
Till then, you might try the Terminal command I posted earlier to see if that can bring back Jack, Soundflower and Finale 2012. If successful, it will have to be rerun every OS update. Since none of those has a kext that prevents booting in Yosemite (unlike Trim Enabler), there's no harm in trying. To restore kext checking, clear the NV RAM (PRAM), reinstall Yosemite or wait for the next OS update.
I would remove old unused kexts and then turn off TRIM if you're using Trim Enabler. Then install Yosemite. I do everything with terminal commands these days. Kexts are like the old Extensions in Classic MacOS. I'd re-enable TRIM with the command line. That is if there are no further issues. I have yet to install Yosemite.
Anyway, yes is the answer to your question.
Re: Yosemite
Anybody who has Masterwriter 2.0 that upgraded to Yosemite. I installed Java SE and the app works fine EXCEPT for the audio part. When I click an the audio section for a song I get the error message asking if quicktime is installed and something about a subaudio something. Any similar errors for anybody else?
Dual 2.4 GHz Intel Core 2 Duo w/4. GB RAM, OS 10.6.8 DP 7.24, MOTU MIDI express, slew of plugins, Roland Fantom XR, Motif Rack ES, Old Triton
Re: Yosemite
Now SoundFlower is working in Yosemite. I guess I missed something yesterday when I first installed it. Happy Days.
Re: Yosemite
The latest version of Menu Meters 1.7 from May 2014 won't work. Yosemite will not let it be placed in the menu bar. Is there a reasonable alternative that works with Y?
- Tesionman
Re: Yosemite
Everything working perfectly with Yosemite on my end with my Duet 2 and my 8pre's!
I'm really digging Yosemite!
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
- Steve Steele
Re: Yosemite
I keep Activity Monitor, the CPU meter and CPU History open in its own desktop. With my trackpad, Magic Mouse or control arrow key I can quickly gesture and look at that desktop, see a bunch of info, and quickly get back. I found that a lot more sensible than menu meters. That's just me though.bayswater wrote:The latest version of Menu Meters 1.7 from May 2014 won't work. Yosemite will not let it be placed in the menu bar. Is there a reasonable alternative that works with Y?
Re: Yosemite
I'll look into that nightwatch. Meanwhile, iStat Menus looks like a possibility.
- Shooshie
Re: Yosemite
Do you still have the installer for MM 1.6? I don't know if it would let you install it or not, but that's the version I have, and it's working in Y. All options appear to be available.bayswater wrote:The latest version of Menu Meters 1.7 from May 2014 won't work. Yosemite will not let it be placed in the menu bar. Is there a reasonable alternative that works with Y?
Shoosh
- Shooshie
Re: Yosemite
I can confirm this. When the Finder is working, it's much faster. Too soon to explain exactly how or why, but I'll report back when I know something. Of course, I'm dealing with the problem of the Finder hanging. I'm not sure what causes it to crash, but it seems to be happening less. Nevertheless, it still happens. I sure wish I could figure out why. I'll study logs again. I'd given up finding the source in the logs, because there just didn't seem to be a pattern. There are many things that show up prior to a hang, but they also show up thousands of other times.There's nothing to indicate that one or more may be involved in the problem. Maybe in Yosemite their logging practices will have changed, and I'll find something. (yeah, I know; very doubtful that they've changed their logging.cuttime wrote:Another thing I really like is the Finder is much faster than the sluggish Mavericks Finder. Snappy even.
But the Finder DEFINITELY runs faster.
I'm still hacked off that folder custom icons do not display on the desktop. They DO display inside another folder, just not on the desktop. Get Info, and you'll see the icon in the info panel, but... not on the desktop. This was probably a move by Jonny Ive to make the Desktop conform to their design, since it's the most visible part of any display. I don't like that word "conform," at least not when it comes to my options as a user, so this is a black mark against Apple, IMO. This is the company that always told us things like "think different." Apparently that now means "think differently than you used to."
I'm also getting very weary of the Quicklook full-screen slide show bug. Probably not a bug, but again some sort of "feature." In short, it won't magnify small images (except for the first one) to full-screen unless you either hold down the OPTION key the whole time, or go through a slightly cumbersome routine each time you start a show:
- 1) Select the pictures you want,
2) Open Quicklook with Spacebar only or Command-Y (no OPTION key)
3) Increase the size of the picture in any direction by any amount
4) Click the full-screen arrows (previously at the top-right, now at the top left of the window in Yosemite)
5) Once the full-screen slide show is open, hit Spacebar to play/pause.
Re: Yosemite
I'll try V1.6. But it looks like its something you can keep in place with an upgrade, but not something you can install anew. Like Elemental plugins.
- Shooshie
Re: Yosemite
That's what I was kind of afraid of. On the positive side, MenuMeters seems to get updated periodically. Maybe they'll put out a Y update.bayswater wrote:I'll try V1.6. But it looks like its something you can keep in place with an upgrade, but not something you can install anew. Like Elemental plugins.
- Steve Steele
Re: Yosemite
When I was at Apple, in 1996, I worked the highest level of tech support. We only handled servers. enterprise and other advanced clients. Apple Enginerres would never talk to us, return our emails, nothing. We had many good suggestions as we had our pulse on what was trending and what was about to go wrong. If they only would have taken us seriously so many problems could have been avoided and problems could have been solved so much faster.Shooshie wrote:[Of course, just try reporting something like this to Apple. If you think MOTU is difficult to reach, and generally unresponsive, they are positively sociable compared to Apple, which has become a fortress of user-free bliss for the people who work there.
Steve
- FutureLegends
Re: Yosemite
Don't think I have ever done that. So, no.Shooshie wrote: Doesn't everyone use Quicklook for slide shows?
Re: Yosemite
I have no problem with MasterWriter 2 after I installed the Java 6 Run Time that I linked earlier. Unfortunately, I can't test audio support since I have never used that function. Audio was broken in Mavericks for awhile then it came back.
Older MW 2 versions do not update properly if too out of date. My build is 2.0.0.56 (R24). If your build is older, deactivate the license, download the latest build as a trial if you can, install and re-activate the license.
I am updating my wife's 2011 iMac without disabling Kext checking.
Microsoft Office 2008, FileMaker Pro 11.04, Roxio EZ VHS to DVD Capture, Photoshop Elements 6.0, FinancesOSX 2.3a, Final Draft 8.0.3.1, GEDitCOM II all work.
Most MarinerSoft apps work. Write has limited functionality. MacJournal crashed while updating--reopening showed the latest version correctly installed. Montage and Contour are fine as is StoryMill 4.
