Metering. Any Suggestions?
- Bennie Sims
I am learning somethings about loudness and measurement and found that I need an accurate way of metering in the mastering lab or DP 8. Any suggestions??
Mac Pro Six Core Trashcan OX.10.13.3,Macbook Pro 2.53 GHz Intel Core i5 OSX 10.11,DP 8.07 and 9.52,Protools 2018.4 and 10.3.9,Logic 10.4.1.,Reason 8,Waves V9.7. Diamond Bundle, Mach Five 3.2.1, Vir 2, Kontakt 5.3, Melodyne Studio 3.2.2.2, Melodyne Single Track, Motu 2804 MK3, Apollo 8 Quad,Apollo 8 Duo,UAD 2 FireWire Quad Satellite, UAD Thunderbolt Quad Satellite, Rosetta 800, Avalon Vt 747sp, Focusrite 4x Red One, UAD 4-710d, Raven MTi 2 3.3.1, Motu MIDI Express XT.
Re: Metering. Any Suggestions?
There are dozen of plug-ins for metering. Most mastering plugins have metering. I suggest you look into something that follows Bob Katz's K-series spec, Dolby LKFS, and/or Dorrough loudness.
DP metering bridge works just fine. At least no TV stations or post houses have complained in the last several years.
Lots of threads on this. Search for metering plugin.
UNless the latest version of DP meter bridge has changed, it is peak reading only. I'd get something that gives some other options like RMS, VU, PPM, etc.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
- bkshepard
As others have said, there are a bunch of really good metering plugins out there. One I just recently found is Spectre, available through the Apple App Store for a sale price of $50. It's an amazing set of meters including actual Loudness (LU) meters. Unfortunately, at the moment, it isn't a plugin, but it's really easy to route your signal from your DAW to Spectre with AUNetSend. According to their website, there is an AU version of Spectre in the works that will run as a plugin.
-Brian
Mac M1 Ultra 20-core, OS 14.3.1, 128 GB RAM, DP 11.3.1, UA Apollo x6
There's also this:
http://www.bluecataudio.com/Products/Bu ... lysisPack/
That's the bundle, but you can get individual meters separately.
- bkshepard
+1 for the Blue Cat plugs! I've got the bundle and really like them. There are 20 different meters in Spectre that go well beyond the stuff in Blue Cat. If you are having to deal with some of the new broadcast loudness requirements, the loudness meters are really handy. Of course, as I mentioned in my earlier post, you have to deal with the fact that they currently don't run as a plugin. Hopefully, the AU versions will be out soon!
-Brian
For free you can't beat Span.
http://www.voxengo.com/product/span/
I use this for a few different things but find it really handy on the master fader to set my final output to -6 before mastering.
- Shooshie
Blue Cat Audio.
I was going to post about them, but I see that others already have, so I'll throw my support in with them.
- buzzsmith
What Shooshie said.Shooshie wrote:Blue Cat Audio.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I've been using Melda's Loudness Analyzer lately. I really like it. Melda's got some good plugs in general.
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.5/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
- Dwetmaster
izotope insight
We have the bluecat bundle, insight, all the waves stuff. we like Bluecat, but... alas it does not do weighting. ("B","C". etc) Since we got insight, engineer is 90% of time is using those, and 10 % waves dorroughs.
- supersonic
Meldaproduction
Music is movement in silence
