Eventide free plugin
Their channel strip Ultrchannel access code 048D6940 check website
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Eventide free plugin
I found a link here:
http://eventideplugins.elasticbeanstalk ... hannel.jsp
ButI do not know exactly what this "elasticbeanstalk.com" domain means? Best I could gather is it's a way to distribute software through Amazon? So this is legit and sanctioned by Eventide? I'm guessing it is if they deposit an iLok license for it. Interesting.
Also found some info and another code (0F736710) here:
http://www.pro-tools-expert.com/home-pa ... -code.html
It's a legit offer and a really nice channel strip. For what it's worth ,I used the code listed on their announcement @ Gearslutz-0B4968F2.
rich
rich
2012 Mac Pro 3.46 Ghz Westmere 12 Core_96G Ram_OSX 10.12.6_DP 9.5
Yes indeed. I just downloaded it and my iLok license was deposited almost instantly after submitting the form. Cool plug!
- buzzsmith
Going for it in a few minutes. (Actually, I'm commenting so I won't lose the link on the iPad!)
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- bolla
Grab it while you can.
The pitch shift option is great.
Bolla
Bolla
8 Core 2.8 10.11.1 DP 8.07 | Dual 2.5 G5 VEP Slave | PC i7 920 VEP Slave | UAD Sat Quad | MiniMoog
Yep. Even has a cool delay function built in.
Works great.
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
Very cool.
I'm just curious which components within this plug-in are far superior to, say, DP's native EQ, etc. I also have a couple other channel strips, but wonder what the significant sonic difference would be with Eventide's?
I know it is free, but I have to weigh the "cost" of setting up an iLok acct, learning a new plug, etc.
Sounds like maybe I should just shut up and get it.
The built-in pitch shift and stereo delays are things not typically found in channel strip plugs.
Got it - best plugin for the money I've seen all week!
Yeah...those sure aren't my other channel strips (Metric Halo, Waves Renn).HCMarkus wrote:The built-in pitch shift and stereo delays are things not typically found in channel strip plugs.
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 14.1.2
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 10.15.7
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Yea, if you've never used it, the new iLok License Manager takes a couple of minutes to learn. It's not intuitive but you'll figure it out soon enough. This is the perfect opportunity since someone will be depositing a license into the account. The license manager only runs when a license is being added or released. It does not run otherwise.I know it is free, but I have to weigh the "cost" of setting up an iLok acct, learning a new plug, etc.
It's nice that many newer plugs can use it without the hardware dongle. Other companies are using it now - some for their freebies and upgrades as well.
This download was quick, the license was sitting in my iLok account in seconds. This allows two installations without an iLok, iLok only or iLok and one other computer.
Yep, best money I've not spent all month!
The trade-off is that you will get marketing email from Eventide. I know what to do with that.
Not sure I understand what this means? I've launched iLok License Manager many times just to look at what is residing on my iLok. I do have a pending license that I've never installed because it's a duplicate, but seems odd that it wouldn't run unless you had a pending one. Confused.mikehalloran wrote:The license manager only runs when a license is being added or released. It does not run otherwise.
