What is host buffer Mulitplier Mean??
Akai96
Post by Akai96 »
It seems you can set this to 1-4,When I set it to 4 the processor is a lot smoother than when set to 1,Could I trouble someone for some quick info on this?
buzzsmith
Post by buzzsmith »
From MOTU's website...don't know if it addresses your specific question, though!
What is the Host Buffer Multiplier?
If you only have one driver is selected, leave the Host Buffer Multiplier set to 1.
The Host Buffer Multiplier (found under the Setup menu > Configure Audio System > Configure Hardware Driver) improves performance in DP 4 when using more than one hardware driver.
When you are using multiple CoreAudio drivers simultaneously, set the Host Buffer Multiplier set to 2.
Note that when you are using a PCI-324 or 424 system with multiple interfaces connected to the PCI card, the Host Buffer Multiplier should still be set to 1. This is because although you are using multiple interfaces, you are still only using one driver.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Akai96
Post by Akai96 »
Thankyou. :)
burp182
Post by burp182 »
Here's a dopey question - what about 2 of the same PCI cards combined in an Aggregate Device? Does that qualify as 2 drivers? Thanks.
goody_ear
Post by goody_ear »
Umm..to my knowledge it is used to configure how many proccesors(CPU's) your system is running. If you have a dual processor machine then set it to 2.
sdfalk
Post by sdfalk »
goody_ear wrote:Umm..to my knowledge it is used to configure how many proccesors(CPU's) your system is running. If you have a dual processor machine then set it to 2.
No it isn't, it's the number of audio interfaces/drivers.
As buzzsmith stated above if you're running say
4 Motu Interfaces off of one card, you still want it set to
1 as it's only 1 motu audio driver.
The host bus multiplier was Motus way of addressing multiple
audio cards/drivers before apple updated the OS to include aggregate
audio devices (which fundamentally does the same thing.)
A Metric Halo ULN8-3D…mmmmmmm
goody_ear
Post by goody_ear »
Wow, I must have read wrong. I've been under the wrong impression for years...LOL. Guess I better change my settings when I get home from work as I only have 1 2408mk2.
sdfalk
Post by sdfalk »
..I've been mistaken PLENTY of times...lol :D
here's something directly from Apples website regarding aggreagate
audio:
Device Aggregation
Mac OS X Tiger now allows you to use multiple audio devices together to increase the number of input and output channels. You can combine devices of like sampling rate together, whether via FireWire, PCI or built-in, into a single aggregated device. Set up is easy via Audio MIDI Setup and your new ••œvirtual••
johnnytucats
Post by johnnytucats »
So I guess "3" and "4" are for secret unspecified use known only to MOTU. :wink:
johnnytucats wrote:So I guess "3" and "4" are for secret unspecified use known only to MOTU. :wink:
Well, it's possible to have a MOTU interface, a Digidesign, a Firewire MOTU, etc., etc., and maybe even Soundsticks would count as a host for playback. I've never tested that. I add Soundsticks without changing the host buffer multiplier. One could easily get several in there, with several operating drivers.
sdFalk wrote:Just so I'm not talking out of my ass..which I've done before
Now, I'm not saying you have or you haven't done that before... only that I don't want to er... witness your next speech.
:D
sdfalk
Post by sdfalk »
:D
:lol: :lol: :lol:
So close to a William S Burroughs reference..
mastermix
Post by mastermix »
Feel free to think this is some DP voodoo ;-)
A team of DP propellerheads have determibed that:
If you are on a Powerbook, and try a 128 buffer setting with Host Buffer Multiplier of 1, or 2, or 3 or 4 times...which gives;
128, 256, 384 and 512 buffers respectively.
The results will keep your DP/Powerbook a lot happier...minimizing spikes, pops, etc. when using relatively high counts of plugins...
Definitely not in the DP manual.
This is Juju ;-)
Kris..
Rush909
Post by Rush909 »
So here is a question... If I have a PCI-424 and "built in audio", but I only have PCI-424 selected and "active" in configure hardware drivers... then what should I put in the host multiplier???
r.
sdfalk
Post by sdfalk »
Rush909 wrote:So here is a question... If I have a PCI-424 and "built in audio", but I only have PCI-424 selected and "active" in configure hardware drivers... then what should I put in the host multiplier???
r.
1
