Flux VerbV3 problem and workaround
Having an issue with VerbV3 from Flux's IRCAM Tools. Latest version from their site 3.2.16.32133 has a weird issue:
• When first instantiated the plug outputs properly with left & right stereo channels
• As soon as you select a new preset, the right channel output disappears and will not come back.
There is a workaround that isn't too bad. If you close the plug-in window and then re-open it, the right channel comes back and you can then change presets, etc. and output remains stable with both channels present.
All in all not a big deal, but every time you first instantiate this plug, you have to close it and then reopen it before it behaves properly. Probably a Flux issue. Reported to MOTU and filled out a ticket with Flux. Posting it here just in case others having this problem.
