I don't even know if this was an issue to some of you to start with, but with DP7.24 and Waves 7.1.1.6 there's been a problem since at least DP4 (and I report it until now
No matter what Waves plug-in I'm using, if I automate something, and select a point of that parameter, the Event Information window doesn't reflect the true value of the parameter as seen in the plug-in.
For instance, instead of seeing the automation point for a Renaissance Compressor as a Ratio value of 3:1 or 4:1, I see 500.000 or 600.000 in the Event Info window.
Same with its Gain parameter... If I take a snapshot and the Gain parameter is set at the default (0.00 dB in the compressor), and I select it and see it in the Event Info window, it will read 500.000 instead of 0.00.
This makes it impossible to edit plug-in parameters numerically AND graphically because the values and the scales do not correspond, and each parameter seems to be set arbitrarily within a weird range that tells you nothing about the real value. Waves' parameters have a scale (range) from 0 (all the way down) to 1000.000, as seen by DP, no matter what the parameter is. What the heck?
Has that changed with DP8? Please tell me it has...
