sorta OT - DP 7.24 recording THR10C via USB - SOLVED
b.g.
Post by b.g. »
Apologies in advance as this is more about the THR10C than DP. I'm trying to record a Yamaha THR10C guitar amp via its USB output into DP 7.24. The THR USB is not class compliant and requires a Steinberg driver. Once the driver is installed the THR10C appears in DP's audio inputs as THR10C-1 mono track and THR10C-2-3 stereo track. It works, but the problem is the THR10C's USB output level is very weak. DP's audio input meter barely registers. The only way I've found to get a half decent level is to select one of the higher gain models and then crank the Master and Gain. But if I want a clean sound the USB level is way too low. Has anybody else experienced this or have any advice?
MacBook Pro retina 2015, i7, 16GB, DP 10, M4
b.g.
Re: sorta OT - DP 7.24 recording THR10C via USB - SOLVED
Post by b.g. »
I'm pleased to report I'm an idiot. The THR10 USB outputs two stereo pairs--a processed pair and a DI pair. I was looking at the THR10's direct outs, which are very low level. Also, in DP I had to click new stereo bundle to reveal both THR pairs, which I hadn't done. Operator error, as usual.
