Motu 828 MkIII firewire with Thunderbolt adaptor?
Tidwells@aol.com
Post by Tidwells@aol.com »
Hi!
I'm having a hard time finding a straight answer to this on the MOTU website: If I upgrade to a new MacBook Pro which has no Firewire port, will I be able to reliably run my Motu 838 MkIII (firewire only, not hybrid) interface with DP 8 on the new machine by using an Apple Thunderbolt to Firewire Adapter, or is there any other recommended adapter that works better?
Anyone using these? Thanks!
Doug
FutureLegends
Re: Motu 828 MkIII firewire with Thunderbolt adaptor?
Post by FutureLegends »
My 828mk3 works great with my rMBP using the FW-TB adapter!
rigsbalicious
Post by rigsbalicious »
looking at buying new MacBook Pro. Can I run the original MOTU 896 using the thunderbolt to firewire 800 adapter connected to a Firewire 800 to 400 cable? Thx!
mdee
Post by mdee »
rigsbalicious wrote:looking at buying new MacBook Pro. Can I run the original MOTU 896 using the thunderbolt to firewire 800 adapter connected to a Firewire 800 to 400 cable? Thx!
Can you confirm that the original 896 works? I have to help a friend setup a new system. My plan is to use a FW400/FW800 cable and the TB adapter to his new iMac. If you have the 896 working -- what driver version are you using on your system? Thanks.
27 inch iMac 3.6 GHz Intel Core i9 40GB Ram - macOS Sonoma 14.3.1
Logic Pro X 10.8.1 - Performer Lite 11.23 - LUNA 1.5.3
Apollo X6 - UAD 11.1.0 - UAD OX 1.2
There are reports that the 1st gen 896, like the 8pre, will not work with the TB-FW adapter. Best to ask MOTU directly.
Xandra
Post by Xandra »
Did you get a reply to your question? I have a similar question if you look in the hardware/windows forum. I'm thinking that it is only possible with Cuemix (and maybe the 828) to mix inputs onto a bus and send the bus out to the mains or the phones. You can't do this with outputs, unless I am missing something that you are trying to do.
You can check out our latest 1z0-050 practice test - pass4sure.co.uk and IBQH exams written by our certified teams to help you pass Rockefeller University .
