DP8 & Izotopes Alloy Side Chain...does it work for you?
csiaudio
Location: Indiana; Where the corn is tall and the women are wide!
Post by csiaudio »
If anyone has Izotope's Alloy and DP8 can you check to see if the Side Chain feature works? It's not here. I'm wondering if this is a DP8 or Izotope issue??
Capturing the Colors of Sound!
Mac Mini M1 2020 -- DP 11.2 -- Universal Audio Apollo Quad -- Apollo Twin -- SPL Kultube Compressor -- Slate Virtual Mic -- Eve SC207's w/KRK Sub
wessel9
Re: DP8 & Izotopes Alloy Side Chain...does it work for you?
Post by wessel9 »
The sidechain feature in Alloy is not working for me either - the menu where you select the input source doesn't even show up. Is this the problem for you? No way to tell Alloy's dynamics modules which bus to listen to. Seems to be a problem with DP, as it clearly works in ProTools.
Which version of Alloy? Alloy doesn't work in 64bit but both Alloy and Alloy 2 work with DP 8 32bit.
