Is audio patch thru with effects working for you in 8.05?
zandurian
Post by zandurian »
Because here it doesn't seem to be working. I have rarely used the feature but it seemed like all I had to do was insert the plug and if the track was armed to record and if I had patch thru audio enabled it automatically output the effected signal live.
I have the raw input signal loud and clear - and the DP mixer controls the volume of that output etc - just no effect. If I hit record and rewind/play the track back the effects work perfectly.
I went to the manual but it only confirmed that this is the way it's supposed to work. I tried clicking the track speaker icon, no change.
Any ideas?
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
Gravity Jim
Re: Is audio patch thru with effects working for you in 8.05
Post by Gravity Jim »
Yep, works fine here.
Jim Bordner
magicd
Post by magicd »
Go to:
Setup menu>Configure Audio System>Input Monitoring Mode...
Check the box to monitor record-enabled tracks through effects.
Ok now?
Dave
zandurian
Post by zandurian »
magicd wrote:Go to:
Ok now?
Dave
YES! Thanks Dave.
magicd wrote:Go to:
Ok now?
Dave
That's what I'm talking' about! MOTU and MagicD totally rock!
:headbang: :unicorn:
