DP and Mavericks
Re: DP and Mavericks
Working well for me. Mavericks fixed the big issue I had with DP 8.05 so I'm a happy camper. Liking everything else I see.
- dado
Installed this morning. Less cpu usage!!!
iMac 27" 3 ghz 32 Giga ram / DP 11 / Motu UltraLite mK4/ TLAudio Ivory 5051 / Addictive Drum2 / PRS Custom22 Guitar / Boss Katana100 / Line 6 Variax700 / Strat by Tino Tedesco
Does this mean that DP under Mavericks is... snappier?dado wrote:Installed this morning. Less cpu usage!!!
Dave
It appears to me that Mavericks is designed to encourage use of iCloud. How many out there are currently using iCloud to any significant degree? Is it of benefit while using DP? Can a DP project be manipulated on two different computers simultaneously?
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Come for the DAW. Stay for the snap.
Or is it the other way around?
- dado
It needs less ram and less stress on the processormagicd wrote:Does this mean that DP under Mavericks is... snappier?dado wrote:Installed this morning. Less cpu usage!!!![]()
Dave
I called them. Tech support assured me all is well.williemyers wrote:Mike, just wondering where you saw this? I've just checked MOTU's website for the 8.05 releasemikeka wrote:From MOTU: DP 8 is Mavericks ready and has been tested with the new OS. I'm in the middle of a mix but will install after completion.
http://www.motu.com/newsitems/dp-805-is-now-shipping
and there's no mention at all about Maverick that I can find?
DP 8.07 64 bit, OS 10.10.5, Mac Pro 5,1 12-core 3.33ghz, 16GB ram, lots 'o plugs and VIs
- Drumwizard
DP's Delay and Modulation effects do not work correctly with Tempo Lock to Beats or Note Value.
- dave pine
that's not good, have you tried any third party plugs synched to bpm?
mac pro 2.26 octacore 24gigs of ram/ El Capitan10.11, dp 10, mackie dxb, 3-2408mk3, waves mercury 10, ozone 3&4&5678, sound toys, izotope rx, melodyne editor, uad 2, bluetubes, 22" polkadotted dildo, omnishpere 2, trigger 2 deluxe, addictive drums, komplete 9, e/w ql symphonic orq platinum, ql choirs, ql stormdrum 2, ql gypsy, ql ra, ql goliath, ql pianos, superior drummer 3, ez drummer 2, garritan bigband, amg kickass brass, ztar, wife, dogs, droped my protools rig at the city dump
- Drumwizard
Yep. Waves SuperTap Delay works as it should in sync mode.dave pine wrote:that's not good, have you tried any third party plugs synched to bpm?
- Drumwizard
When I click on '+' or '-' (under knob) it's step =2 instead of 1. For example, to increase gain I click on '+' several times and it grows like 2, 4, 6, 8 etc.
I haven't tried the Delay plug yet, but everything I've tried so far is working great. DP8/Mavericks may just be a winning combination.
I'm curious if anyone is running DP 7 with Mavericks?
I can almost guarantee you that's because they're competent developers who follow best practices. I.e., they RTFM and don't do weird hacks that rely on deprecated code, etc.wvandyck wrote:MOTU is always ready in advance!mikeka wrote:From MOTU: DP 8 is Mavericks ready and has been tested with the new OS. I'm in the middle of a mix but will install after completion.
That continues to impress me, more so now than ever before.
Meanwhile Avid/Digidesign... cough... I've had more *****ing problems with their **** drivers over the ******* years than any other piece of ******* I've ever ********* owned. And I *just* got my Digi 002 Rack to *kind of* play nice with Mountain Lion, by having two versions of the driver simultaneously installed, and using terminal commands to selectively load/unload the version of the driver I need at any given time... sigh... I have to say when it works, it works well, but it's been such a pain.
MOTU on the other hand is a godsend when it comes to drivers.
-=DG=-
_________
Vocals/Synths
Sawblade Painter
https://soundcloud.com/sawbladepainter
Moonbase Zeta
https://soundcloud.com/moonbasezeta
_________
2021 MacBook Pro 16" M1 Max, 64 GB RAM, 8TB
MOTU 896HD (Black Lion Mod) | MOTU 828 Mk II | Korg X2, RK-100S Mk 2 | Yamaha Electone 7000 | Behringer ARP 2600 | Alesis Photon X25 | iPad Pro 12.9" | Line6 MobileKeys 49 | SoundCraft Delta 200 16•4•4 | DP8 & DP11
_________
Vocals/Synths
Sawblade Painter
Moonbase Zeta
_________
I use iCloud a little bit, mostly for Notes syncing. As an iOS developer, I can tell you there have been a host of issues with certain aspects of iCloud in the past, when it comes to a certain kind of fine-grained, database-level syncing that Apple offers. iOS 7 was supposed to address that and I'm sure Mavericks includes these improvements as well, since the core-level stuff tends to be pretty similar if not identical between the two OS's (and is becoming more so).nick danger wrote:It appears to me that Mavericks is designed to encourage use of iCloud. How many out there are currently using iCloud to any significant degree? Is it of benefit while using DP? Can a DP project be manipulated on two different computers simultaneously?
What *has* worked well for third-party developers and iCloud is the ability to have your app simply save a document to iCloud that will be accessible from elsewhere. I'm not sure how it handles two people simultaneously working on the same file, but given that iOS is designed as a single-user system, I don't think they are worried about you editing a document on your iPad with one hand, WHILE you edit it on your Mac with the other.
However when it comes to something like Digital Performer, I kind of don't see what the usefulness of iCloud would be. My average DP projects are in the range of ~5-10GB. I suppose that could be backed up to iCloud simply for backup purposes but I don't see how multiple people editing that iCloud project simultaneously would even be desirable, let alone possible.
You have to look at something like Github to get an idea of what a major project being edited by multiple people simultaneously might look like. You start to realize that even in the case of a large set of text documents full of computer code, synchronizing changes between multiple different versions and branches can become incredibly complex.
It would be very difficult indeed to create a revision tracking system like Git for something like a DP project, with all its tracks data, plug-ins assignment data, automation data, mix data, MIDI data, take data, etc. How would you compare two versions of a DP project? In programming every program is broken up into many different source files. It would be like if each individual track, automation control, MIDI track, etc. in your project had its own separate file for each take. As it stands, audio is kept in separate files but most everything else is all inside the DP project file itself. I have no idea what method of storage MOTU uses inside these files. If it's CoreData, then theoretically there might be a way to merge the changes between two different versions of a project file, rather than simply choosing one or the other.
However from what I do know about CoreData, I am quite sure that to attempt such a feature would be a monumental undertaking, and to get it to work with iCloud would be something no sane developer would dare even consider, let alone attempt, unless the success or failure of the product depended entirely on that feature alone. Even then they would probably have cold sweats at night.
GIven DP's support for the branching undo's however, I do think if any developer were to be capable of doing this, MOTU would be the one, because the same underpinnings that allow an undo history to be possible are also what allows document revision tracking and change syncing to be possible (in a general, categorical sense).
-=DG=-
_________
Vocals/Synths
Sawblade Painter
Moonbase Zeta
_________
_________
Vocals/Synths
Sawblade Painter
Moonbase Zeta
_________
