DP 8.05
chaim
Re: DP 8.05
Post by chaim »
• Option-clicking a window's close button now closes all similar windows
I tried this on a clipping window while having another couple of them open, did not work to close all of them. :?
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
chaim
Re: DP 8.05
Post by chaim »
My DP CD burning test worked fine. I burned 74 minutes 11 tracks. Successful.
corbo-billy
Re: DP 8.05
Post by corbo-billy »
toodamnhip wrote:
James Steele wrote:
Phil O wrote:Update on my last post. This only seems to be happening on audio tracks. I can resize MIDI, aux, master fader, and conductor track by dragging. :? Is there a lock audio track size button somewhere or somethin'
Dunno. Here I am again. DP 8.05. Resizing an audio track.
It don't work at home, under 10.6.8. with this 8.05 version . :oops:
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
Re: DP 8.05
corbo-billy wrote:It don't work at home, under 10.6.8. with this 8.05 version . :oops:
That's odd, because you see the screen capture? That's taken with 10.6.8 with DP 8.05. So not sure how it's working for ME with the SAME OS and SAME version of DP, but not for you. :?:
corbo-billy
Re: DP 8.05
James Steele wrote:That's odd, because you see the screen capture?
I look at the screencapture from a G5 running under Tiger 10.4. _ I meant resize tracks function that don't work on the Mac Pro running under Snow Léopard ! :wink:
Re: DP 8.05
Not sure I understand. The screen capture I posted shows resizing the tracks on my computer which IS running DP 8.05 on a MacPro 1,1 with Snow Leopard.
Dan Worley
Re: DP 8.05
Post by Dan Worley »
I posted a short video about Paste To Wiper in Video Tutorials.
http://www.motunation.com/forum/viewtop ... 27&t=55867
DP10.13
corbo-billy
Re: DP 8.05
James Steele wrote:Not sure I understand. The screen capture I posted shows resizing the tracks on my computer which IS running DP 8.05 on a MacPro 1,1 with Snow Leopard.
So I pointed out that this function does not work for me .
Re: DP 8.05
Right... I didn't know why you mentioned the G5 running under Tiger, etc? Anyway, it is strange that it won't work for you but it does work for me on similar systems. :?:
Reason: Mistakenly referenced "G4" instead of "G5 running under Tiger"
iFra
Re: DP 8.05
Post by iFra »
toodamnhip wrote:
iFra wrote:Hi..
One only observation... One option is still missing in this version of software.....
The function "COMPARE" when you change the values of the plug-ins does not work with the UAD plug-ins, does not work with plug-ins "DUENDE NATIVE" and does not work with plug-ins "WAVES". Only works with the format MAS.
It would be great to put at the disposal of DP8 this command as it is made available in Logic9 or in Cubase. Being DP a software much nicer and professional, this function should not remain only for the other softwares mentioned...
I use "compare" in iZotope Ozone 5. Have you checked to see if it works there?
I'm sorry. I do not use Ozone ... to you the "Compare" function works good with this instrumet?
Mac Pro 8 core 2.8Ghz (2008), 16Gb Ram, OsX Mountain Lion 10.8.5 - Digital Performer 8.05 - Logic 9 - 2x Uad Duo, Waves Plug-ins, Duende Native, Superior Drummer Instruments, Ez Keys Instruments, etc.- Motu 2408, Pci-e 424 - 2x Apogee Rosetta 192Khz - Rme Adi08Pro Ds - ISA Stereo ADC - Avalon VT737 - Universal Audio 2610 - Focusrite Isa 430 - Audient Asp 008 - Focusrite OctoPre - Presonus Central Station D/A - Spectrum Analyzer Samsung D1500, etc. - http://about.me/rivierarecordingstudio
corbo-billy
Re: DP 8.05
Sorry for the confusion, James: blame the translator ! :oops:
It works fine now and I'll make a tutorial for french D.P. 's users for this improvement after this D.P. 8.05. update very important for ergonomics . .
Phil O
Re: DP 8.05
Post by Phil O »
Just to be clear (in case you missed all my posts) - I later posted that the problem I was having with this, as well as a few other bugs, was cleared up after a re-install. The drag to resize feature is now working as expected and the other bugs are gone.
toodamnhip
Re: DP 8.05
Post by toodamnhip »
DP 8.05 still appears to have a bug in data entry in the newer waves plugs in the SE window.
Now, the buggy pull downs have been fixed, this is good. But when one tried to manually enter an amount of an edit point in the data window, it does not work. You can;t even click with a mouse and drag the amounts. So, one step forward one step not.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
delcosmos
Re: DP 8.05
Post by delcosmos »
toodamnhip wrote:DP 8.05 still appears to have a bug in data entry in the newer waves plugs in the SE window.
Well, this is weird. I'm using the new J37 among other Waves plug in and everything is working good.
In fact, I already produced 2 full songs with hundred of tracks and plug ins, with many VI's, tons of pitch editing and didn't had a single crash. Even with a session of Ableton Live slaved via rewire in the back.
I'm using a MAC PRO Dual Eight Core Intel Xeon 2.93, 16gb. MAC OS X:10.8.4 with 3 monitors powered by two 'ATi Radeon HD 7970 OC 3GB' cards and PCI 424 running three 2408's.
Wondering what's causing the problems to you and other people. For me this is one of the best DP Updates ever!
8.07 64bit, Spire, Nexus, Fab FilterDiva, Gladiator, Nexus, Sylenth, Stylus RMX, Live 9, Reason 6.5, Komplete 8, AD Keys, AD Drums, Geist, Ivory, Waves 9 Mercury, Sound Toys, Fab, VEPro, Reason, Live, UAD2, x3 2408mk3, PCI424, MAC PRO Dual 3.46 Ghz 12 core Intel Xeon, Memory: 64gb ram, MAC OS X: 10.8.6
toodamnhip
Re: DP 8.05
So youre saying that you can go into the SE window, click an automation point, go up to the data window at the top of the SE and ENTER a different value?
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
