Missing paraEQ
lunaticDP
Missing paraEQ
Post by lunaticDP »
Since I have updated to Tiger and made a completely new installation of dp 4.6 my parametric EQ doesn‘t show up in the mixing console. It is in the plug ins folder and dp also shows "loading paraEQ" on startup, but I can not choose in the inserts. Also the Masterworks EQ only shows up as <stereo>.
Has anybody had the same troubles? My (German) support, which is normaly very good also doesen‘t know the reason. We trashed the preferences, newly installed the 4.6 update, but now I am finished with my ideas...
please help us!
thx
lu
Roover
Post by Roover »
I have the same problem with the paraeq bundle and masterworks eq. Don't know what's wrong. Can't find the problem either. One time it was all fine but the next day everything dissapeared again. Anyone, ideas
Greets
Roover
Grigri
Post by Grigri »
Hello.
I had the same trouble here.
I have used this application - FONT FINAGLER 0.5.3 - it cleans the fonts cache.
Here's a link for version tracker:
http://www.versiontracker.com/dyn/moreinfo/macosx/22795
I think there is a corruption on the fonts that bug the parar eq plugs.
Hope that helps
Grigri
Digital Performer 11.31 - Mac OS Sonoma 14.6.1
dactarus
Post by dactarus »
Hi,
exactly the same trouble here : from one day to another, after upgrading to 6.1, the equaliser & Para Eq plugs disapear... But still present in the plug folder. I try to trash pref, repair perm, etc. Finaly had to re-install DP to fix it. No trouble since.
Emmanuel
Roover
Post by Roover »
Tried to reinstall DP. Used the fontcache cleaner. Didn't work. The Eq's are still missing. I'm open to other suggestions.
Roover
alobonzo
Post by alobonzo »
Hi
had the same problem, tried to reinstall everything and didn't solve the problem.
But I found a trick, it seems that DP has a bug with the Languaje preferences of the machine, I found this one 'cause my powerbook was in Spanish, and I changed the International preferences to English and restarted the powerbook, I see everything with 4.5 or 4.6, menus, Lost plugins...., etc...
Changed again the international preferences to Spanish and the menus are ok,
give it a try, hope this helps
Alo
PB G4+Presonus Firestudio+DP
iMac Core2Duo + Cubase4+Toneport UX2
Apple Certified Trainer - Final Cut Pro 6
Roover
Post by Roover »
Alobonzo, thanks for the tip. It actually works.
Greets
Eric
felipemusica
Post by felipemusica »
viva Alobonzo!!!
powerbook 1.25 • 1 giga • 828mkII • DP 4.6 • Machfive • MSI •
alobonzo
Post by alobonzo »
If the problem comes again, do the same trick, it happened again to me, seems like 10.4.4 don't corrupt the preferences, by now!
greetings
gjensse
Re: Missing paraEQ
Post by gjensse »
Thanks for the tip! i have been struggling with this problem for days! Changing from Norwegian to English solved it.
Mac Mini M1 2020, OSX 14.7, DP 11.33, MOTU 16A, MOTU 8A, MOTU UltraLite AVB.
