I am new to DP and Mac. I tried searching for an answer but couldn't find anything close. I am using DP8 with an iMac 27, 10.8.5, 3.4Ghz Intel Core i7, with 8 gig RAM.
When I originally set this up, I was using a Lexicon Omega (that I used with my windows system) and had crashing issues in DP. I recently upgraded to a Track 16. The crashes have stopped, however I am having difficulty with the MIDI. Audio works great.
I have tried using K5, Alicia's Keys, and Model 12 all with the same results. I can trigger the soft synths using the software triggers perfectly. When I trigger using my keyboard (Casio WK-3200, local off) through the Track 16 MIDI, the notes don't sound every time I play the key, hitting the same key triggers different pitches, and the notes get stuck on. This keyboard does not have a USB. I didn't have this issue when using the Omega.
The only other issue is that I have to use the wall wart when using Fire Wire for the Track 16. Any suggestions or ideas would be greatly appreciated.
Thank you
Bill
Newbie Track 16 MIDI issue
iMac 27, OSX 10.8.2, 3.4 Ghz Intel Core i7, 8 GB RAM, DP 8, Lexicon Omega, NI B4II, Alicia's Keys, EZdrummer, and a little imagination.
