896mk3 FW won't connect
jonwormwood
Post by jonwormwood »
I have a 828mk3 hybrid and Ultralitemk3 FW and they work fine but the 896 won't connect... I've reset the unit and nothing. Do I need to send it in?
777artin38
Re: 896mk3 FW won't connect
Post by 777artin38 »
Here is a response i wrote to a guy having issues with his 828MKIII :
- Is your 828 the only thing on the firewire bus?
- Have you tried using your 828 on the USB port.
- Can you route audio without firewire connection?
- If you can route audio in your 828 but cannot make connection (on the firewire port) with your Mac well.........you might have stumble on a burnt out firewire port. My 3 828MKIIs all did this in the same time frame (6 years)......even 1 that was never disconnected from the computer. Good news is that i have found a fix. It's a 2$ part. I've put a DIY thread on here that you can check.
Klaus
Post by Klaus »
777artin38 wrote:Here is a response i wrote to a guy having issues with his 828MKIII :
I think it was about an 896mk3...
but here we go :
Could you post a link to your DIY post, please
Best
Klaus
777artin38
828MKII / 896MKIII firewire problem.........same difference.
http://www.motunation.com/forum/viewtop ... 672569ac31
