amplidood wrote:3. Colors have been slightly messed up with new system.
In what way Andy?
Yeah I've heard about doing that in the past...it kinda reminds me of how a PC works - you have to do this and do that first to do something. Yet, when working in say Pro Tools, you select the Volume control and click on the track it defaults to where the fader it at that time. Simple. One click instead some convoluted way of getting the job done fast.bayswater wrote:I think the basic procedure here is to do a snapshot on all tracks, all parms, before you start adjusting automation values. That sets an initial value at the start of the track, and when you go to the automation lanes and click, you can see what is happening.csiaudio wrote: if you want to draw volume control on any track you need to look at the track to see where the fader/level currently is before you click on the volume control line. Because when you click on the volume control line it goes where ever you click and doesn't default to where the fader currently is.
A quick way of getting a line of any parameter where there's none, is to simply enable the Record Automation button for the needed tracks, play the sequence and click on the faders (or any other parameter). This will put a vector in the tracks that you click reflecting the current value.csiaudio wrote:
I suppose when you do this procedure 40 or 50 times a day as I do it would be nice if it was more simplistic.
Its a single click for all tracks if you have automation settings the right way. Not one per track.csiaudio wrote:bayswater wrote: Yeah I've heard about doing that in the past...it kinda reminds me of how a PC works - you have to do this and do that first to do something. Yet, when working in say Pro Tools, you select the Volume control and click on the track it defaults to where the fader it at that time. Simple. One click instead some convoluted way of getting the job done fast.
That's been on my wish list since day 1. Not just sends and outputs though, but a block diagram of the entire signal from source to monitor. And one that includes the Cuemix signal path if you're using it. I had one for my mixer on the wall, and referred to it all the time when setting up.Julia123 wrote:I would like to be able to see an overview diagram of all sends and outputs from tracks and which aux's they are going to.
Quite possible. I had a bit of lag on DP 7 with my G5. With the iMac and DP 8, no lag at all.Crashdown wrote:Does this have to do with my Graphic Card?
Wow. I would LOVE to have that as well. See, RG? Now I really want it!Radiogal wrote:
I´d also like to being able to select tracks in the TO/SE window and the Mixer Window simultaneously. So that the Mixer window track will be highlighted when clicking/selecting track(s) in the TO/SE and vice versa. Again when working in multiple screens with the Mixer Window on a separate screen. This would be great for selecting and viewing temporary track groups and other functions.
You mean some other DAW does that? Let me guess.. PT?Radiogal wrote:I really do miss this feature.
+ 1000!!!!delcosmos wrote:I would like an "i/o" plug in like Logic's, that allow us to use hardware inserts.
Or like PT's hardware insert with built in latency comp.
That could be awesome! I've been waiting this feature for years.
I remember an Sound on sound from 2005 where they said: "hardware inserts on DP is not implemented yet, expect this feature from motu soon".
+1001delcosmos wrote:I would like an "i/o" plug in like Logic's, that allow us to use hardware inserts.
