Hi,
I've not used the DP Control app with DP7.24 for a while, when I last used it it worked fine. I went to use it the other day but it did not work. Went in to control surface setup in DP and saw that the option to setup open sound is no longer in the drop down list, just my faderport & EuCon. As I have recently installed DP8 I went and looked in there and the open sound option is there and DP Control app works fine. So I am guessing that installing DP8 has somehow changed the control surface options in DP7.24 as I don't remember EuCon being there before.
Any thoughts, yes I do still need to use DP7.24 on a regular basis for now.
Steve
DP Control & DP 7.24 not working since installing DP8
2018 3.2 GHz 6-Core Intel Core i7 16GB. External SSD Sample Drives. macOS Monterey 12.2. MOTU 624 & 8D. Cubase Pro 11, Wavelab Pro 11, DP 9.52, DSP Quattro 5. Arturia, Gforce, iZotope, NI, Plugin Alliance, Slate, SSD5, Soniccouture, Spectrasonics, Spitfire. Novation 61 SLMKII, JBL LSR 305, Sennheiser HD600, AKG 240MKII. PRS, Martin Guitars, Mensinger Bass. Vox & Orange amps. Line 6 Helix.
Re: DP Control & DP 7.24 not working since installing DP8
My DP Control is working with DP 8.0 but the stop button no longer works in rewind mode and the record button sometimes works/sometimes doesn't.
Geoff
Geoff
Room A - MacPro 2.66 (early 2x Intel Core2 Duo) - 12G ram, MOTU HD192, Lion 10.7.5, DP8.0 64 bit/StylusRMX/EZDrummer/Superior/GForce Tron/Kontakt 5/ other various plugs
Room B- PCAL Quad 3.0ghz, 16 gigs ram, Windows 7 Pro;
Cubase 8, MOTU 896; various plugs and instruments
