Host automation
Host automation
Hello all. I'm trying to figure out how to get host automation to work with Kontakt and DP. I've searched around and the only things I can find are references to older versions of both DP and Kontakt and threads saying it doesn't work. Has this been fixed? MIDI CC is working but I often like to use host automation instead.
- supersonic
Re: Host automation
Do you mean moving parameters in Kontakt and recording the moves in DP?
Music is movement in silence
Re: Host automation
yes. That's exactly what I mean. Kontakt has the automation pane that shows MIDI CC as well as host automation. I'm wondering how I record the host automation. Some of the libraries I use come with host automation already assigned and I'd like to use those parameters instead of MIDI CC messages. Is this possible in DP?
thanks for the reply!
- supersonic
Re: Host automation
Did you try hitting the rec automation button on the insument channel and moving the parameter?
