Problems with double-clicking audio files
JZilla
Post by JZilla »
Hi there. This is probably a totally stupid thing that I'm overlooking, but hopefully someone can help. Lately for some reason, when I double-click an audio file in the Tracks window to open the track in the Sequence editor, it doesn't take me directly to the track I've clicked on. Most of the time it goes to the top of the sequence, other times it'll be some apparently random track in the sequence. Of course I can scroll down to the appropriate track, but in a large template it is a little annoying.
I'm not sure when the problem started specifically, but it's been within the past month or two, and I can't think of any setting that I would've changed that would've affected things. Any ideas?
Thanks.
Jeff
2019 MacPro, 10.15.5, 16 core 3.2 GHz, 384 GB RAM
DP 10.11
Kontakt 6.2.2, Spectrasonics, u-he, Arturia, NI Komplete 11, VE Pro
UAD, Waves, Soundtoys, Slate, FabFilter
Dan Worley
Re: Problems with double-clicking audio files
Post by Dan Worley »
You're not alone. Other people have reported this bad behavior. Probably best to tell MOTU so they can it get fixed in time for the next update.
DP10.13
tommymandel
Post by tommymandel »
Ditto Dan's reply. In the mean time, if you double-click on the track's name in that window, at least you'll end up closer to where we would have been by DP's pre-8.04 behavior.
