Mach Five 3 bus assign in Pro Tools 10
Hi guys... How can i assign the outputs of the parts in Mach Five 3.1.4 to the Pro Tools busses in order to record multiple parts on different audio tracks at the same time? I use Pro Tools 10.3.6
Re: Mach Five 3 bus assign in Pro Tools 10
Hi there
Select Out 2 in MachFive
Create an Audio or Aux track - look at input and you you see the drop-down menu list interface, bus and plugin. The plugin option should give a further drop down list where you should see MachFive and all its output options. Just tried it in 10.3.6 - it works!
Cheers!
SWT
Cheers!
SWT
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Thanks, it works.... ![Smile :-)](./images/smilies/icon_smile.gif)
