Slate FGX with jBridge problem.
I have ran the jbridge scan and it sees FGX vst and passes it, but it will not come up in the plug-in list. Using DP 8.04 in 64 bit mode bridging 32 bit plugs. Slate Trigger shows up okay as well as others. I thought some members were running FGX with jbridge and it was working. Any ideas? Thanks!
- Shooshie
Re: Slate FGX with jBridge problem.
Works great here. I use it daily. It's been a while since I bridged it, and that's the only plugin I've got bridged, so it's not like I memorized the process, but I don't remember anything tricky about it. I just followed their instructions. Be sure all pieces of the puzzle are compatible, follow the instructions, and you should have no problems at all. You do have to set it up before you open it in DP, but I guess you realize that. Once JBridge makes the setup, it's all done -- for all apps. You won't have to do it again.
Sorry I can't lead you through it, but I just don't remember the process. I assure you it works.
