hi
is there a way to change all outputs at once,i' ve juste changed my audio interface ?
thanks
changing all outputs at one
audio assignments pg. 177
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
mlaverty, I just replaced my 828MK2 with a MOTU Traveler, and all my projects that I open need to be changed to analog 1-2 instead of main out 1-2. When you add a new track in an existing project, it will always assign the output to your previous output. You will need to go to "Audio Bundles" and delete the previous output from the "output" tab, and also move the new device to the top of the list.
Just thought I would share what I have experienced.
dpDan
dpDan
