DP8 mute/solo bug
DP8 mute/solo bug
just noticed this happening... could be with 8.02 or 8.03.. not sure if it started with 8 or one of the recent updates...
but.. when i press MUTE or SOLO or RECORD (or INPUT) on the mixer channel strips... it takes either about 2 or 3 seconds to engage.. or disengage. sometimes the button engages right away, if so, it takes 2 or 3 seconds to disengage when i click it again. or, sometimes it takes 2 or 3 seconds to engage, and then disengages right away when i click again.
it's every time, all the time. every channel, etc.
running in 32 bit mode on a 2008 mac pro ... maybe my machine's just too old.
anyone else experiencing this?
Re: DP8 mute/solo bug
I say you are correct in assuming the computer might be struggling.
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
DP8 is that much more resource hungry? perhaps...
if apple would get off their asses and give us new mac pros....
jbyerly1 wrote:I say you are correct in assuming the computer might be struggling.
- Timeline
Isn't this the pref selection to release/mute the plugin resources when muted. I always turned that off in the past.
- Gravity Jim
I run DP8 on a 2008 8-core MacPro and it's plenty responsive. How much RAM do you have and why aren't you running in 64-bit mode?
Also, why do you need Apple to do anything? Buy a refurb 2012 12-core if you think the hardware just isn't up to snuff. Those machines are beasts... Aside from maybe adding Thundbolt, a new MacPro wouldn't perform any better.
Jim Bordner
64bit mode: good question. i've never wanted to go through the hassle of making sure all my plug ins are 64 bit.. and losing ones that aren't...
but i guess, after i finish this project i'm in the middle of, i can try that. probably good to get up to speed (no pun intended).
new mac pro: well, since new ones have been "on the horizon" for over a year now, i hesitate buying a 3 year old machine. this 2008 8 core has been amazing. 5 years on and still running great. this slowdown (also happens when i press play and stop) is the first time i've felt like i needed a new machine.
i have 8 gigs of RAM
Gravity Jim wrote:I run DP8 on a 2008 8-core MacPro and it's plenty responsive. How much RAM do you have and why aren't you running in 64-bit mode?
i switched to 64 bit and loaded my project.. half the plugs didn't load (don't think iv'e udpated UAD in a while..) but, even with 1/2 the plugs not loaded and in 64 bit mode.. it still lagged when muting/unmuting.
I bet this is what's accounting for the delay.Timeline wrote:Isn't this the pref selection to release/mute the plugin resources when muted. I always turned that off in the past.
