strange results in Scale time
jbyerly1
Post by jbyerly1 »
I'll take any suggestions you might have. The first image shows show the entered info.
The second shows the results. This should have shorten by 00.04.00
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
jbyerly1
Re: strange results in Scale time
Post by jbyerly1 »
Looks like I have found a error in the programing. Was able to get the hour+ wav file to tech support and they came up with same results.
reply: " have reproduced your issue and at this point, have not found a fix. It looks as if this needs to be brought to our development team for further investigation. I will keep you posted on any news, but I would not expect an immediate solution."
What a way to make a person insane thinking it was something I was doing wrong
b.g.
Post by b.g. »
Good job on documenting and getting that to tech support's attention. You've done us all a service.
MacBook Pro retina 2015, i7, 16GB, DP 10, M4
Post by Shooshie »
jbyerly1 wrote:Image
Ayiyiyiyi! That's bad news. I hope they fix it soon. I need that.
Shoosh
bralston
Post by bralston »
I wonder if this adding of time is also related to the same reason (similar code) when I bounce a selection of measures to disk with a QT video as the output...it also adds time to the end of the file with blank/black frames at the end. (Yes...I reported it). Hmmmmmm........
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
jbyerly1
Post by jbyerly1 »
I tried a full project freeze (all audio files) which makes every file the exact same length unless I am misunderstanding something.
But the point is I tried a full project scale time with these frozen tracks and the results were all over the place as far as length after processing
labman
Post by labman »
Oh boy. We need that big time.
Help us obewon magic D
David Polich
Post by David Polich »
Yeah, that's a bad bug.
Meanwhile, Melodyne can be your friend in situations like this. That's
what I use to time-scale audio anyway.
http://www.davepolich.com
... Or IRCAM in MachFive.
aweaselkid
Post by aweaselkid »
MIDI Life Crisis wrote:... Or IRCAM in MachFive.
Interesting. Explain?
jbyerly1
Post by jbyerly1 »
Is the Melodyne quality, the results, worth $400.00. It looks like maybe the editor could do what I need
David Polich
jbyerly1 wrote:Is the Melodyne quality, the results, worth $400.00. It looks like maybe the editor could do what I need
IMO, Melodyne is indeed worth every penny, and then some. I'd pay $499 for it.
For me it is not an option, it is a necessity. There are numerous projects
I have done which could not have been realized without Melodyne.
jbyerly1
Post by jbyerly1 »
Thank you for the the opinion. This is the only place I would actually listen to an opinion about software
labman
Post by labman »
I agree with David about the value of melodyne.
