This probably won't happen to you but, if it does...
After I installed DP 8.02, Time Machine stopped working. It would start, run, quit but would not show the last backup as having occurred.
I opened Console to see pages of Access Denied and Unable to Read and deny file-read-data /Library/Audio/Plug-Ins errors. Oops! I forgot to run Repair Permissions. Did that.
Now TM worked but was extremely slow. Console showed line after line of this: sandboxd: mdworker deny mach-lookup com.apple.ls.boxd
Stupid Mac Trick: This error is generally fixed by re-booting your Mac in Safe Mode by holding the Shift key while booting. After it has finished booting, shut down and re-start normally.
Installed DP 8.02, TM Error - How I fixed.
Re: Installed DP 8.02, TM Error - How I fixed.
You mean to say Repair Permissions actually does something...
I am fairly certain that the real problem is a failing hard drive that I am using for TM. After I did the above, I ran a SMART test in TTP 6.
This is the replacement for a Seagate drive I sent under warranty about 8 months ago. This one goes back tomorrow. Fortunately, my WD drives don't look like this.
I dunno... There are a couple or three guys on this board who keep talking about it. Do you know anyone who listens to them?You mean to say Repair Permissions actually does something...
Not anyone who should!
