DP 8 detecting Instrument
hxmusic
Post by hxmusic »
Hi gang. I'm new here and don't use my DP nearly as much as I wish I could.
Sorry if the terms I use are not correct. I'm still learning.
A couple of my instrument tracks are not being recognized when I go to add them to my project. DP is finding my Komplete sounds, but not Ivory or Sample Tank.
Any advice on how to fix this? Thanks.
Re: DP 8 detecting Instrument
Are you launching DP in 32 or 64 bit? You might want to add your machine and OS specs, etc.
hxmusic
Post by hxmusic »
Thanks.
I'm on a 2x2.4 GHz Quad Core Intel Xeon
6 GB 1066 MHz DDR3
Recently upgraded from DP 4.6 to DP 8. I'm assuming 64. How can I verify?
kgdrum
Post by kgdrum »
if the OP is in ML 10.8,he's in 64bit.
from my understanding 10.8 only works in the 64bit kernel,we discussed this a month or 2 ago.
Sampletank is 32bit so you will not see it in the 64bit kernel,some users have gotten it to work via jBridge others like me haven't.
I don't use Ivory so that's one I'm not sure about.
I believe you can still run 32 bit apps in ML. You just can't change how the machine boots.
