Reason rewire and DP 8
Tesionman
Re: Reason rewire and DP 8
Post by Tesionman »
This is highly unacceptable! Hope they fix it pronto!
I'm a heavy Reason user... :x
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
corbo-billy
Post by corbo-billy »
Update for REASON in 6.5.2. version available .
Guitar Gaz
Post by Guitar Gaz »
corbo-billy wrote:Update for REASON in 6.5.2. version available .
Just downloaded it - thanks for the heads up. Tried it with DP8 in 64 bit in Rewire mode. Still crashes - still seems to be CoreMidi and I will report to MOTU again:
Thread 12 Crashed:
0 com.motu.MidiSystem 0x0000000101a695a8 MIDISystem::Setup::Instance() + 3204
1 com.apple.audio.MIDI.CoreMIDI 0x000000010279e378 LocalMIDIReceiverList::HandleMIDIIn(unsigned int, unsigned int, void*, MIDIPacketList const*) + 80
2 com.apple.audio.MIDI.CoreMIDI 0x000000010279d5d8 MIDIProcess::RunMIDIInThread() + 84
3 com.apple.audio.MIDI.CoreMIDI 0x000000010277d96a XThread::RunHelper(void*) + 10
4 com.apple.audio.MIDI.CoreMIDI 0x000000010277d396 CAPThread::Entry(CAPThread*) + 98
5 libsystem_c.dylib 0x00007fff8b7858bf _pthread_start + 335
6 libsystem_c.dylib 0x00007fff8b788b75 thread_start + 13
Gary Shepherd
____________
daniel.sneed
Post by daniel.sneed »
A different experience reported on the other thread
http://www.motunation.com/forum/viewtop ... 02#p439602
Guitar Gaz
daniel.sneed wrote:A different experience reported on the other thread
Not quite sure what this is here for - Motu have already agreed there is a problem so just because one person has no problems it doesn't mean it doesn't exist or all of us with problems are somehow at fault. I am on 10.7.5 whereas that poster was still on Snow Leopard. Either way, this is not a Reason issue but a Motu one as they admit. I am glad someone is not having problems like I am.
Gary Shepherd
____________
daniel.sneed
Yes, Guitar Gaz, only a single experience.
Just hoping to convince DP8 owners to go for a try on second hard drive.
Which I've been late to try, partially cause of negative experiences reported.
Hope DP8/Reason combo behaves smooth soon for everyone.
Guitar Gaz
daniel.sneed wrote:Yes, Guitar Gaz, only a single experience.
I suspect its more to do with you being on Snow Leopard - obviously I am getting a little frustrated having owned DP8 for over 1 month - didn't mean to sound grouchy! It might be worth Motu knowing that Snow Leopard does not have the same problem in your case.
Gary Shepherd
____________
starbearer76
Post by starbearer76 »
I'm trying to run ableton inside of DP8, but rewire channels not showing up in DP aux track at all.
way are the complicated things so simple and the simple things so complicated?
daniel.sneed
Guitar Gaz wrote:If you have a computer that can run apps in 64 bit as well as 32 bit then you in theory should be able to run DP8 rewired with Reason in 64 bit. Both Reason and DP8 can run in 64 bit - you change them by clicking Get Info on the app in Finder - just tick the box if you want the app to load in 32 bit version.
Have checked this one?
Both of them must be 32, or 64, bit at once!
Guitar Gaz
Yes thanks I knew they have to both be either 64 or 32 bit. This issue was solved long ago with the release of 8.01.
Gary Shepherd
____________
daniel.sneed
Thanks for posting Guitargaz.
But sorry, my intent was towards starbearer76's recent post.
Guitar Gaz
daniel.sneed wrote:Thanks for posting Guitargaz.
My bad - your posting came at the same time as a Motu Tech e-mail asking me about the status of this issue - clearly I forgot to tell Motu and this thread it was solved.
Gary Shepherd
____________
starbearer76
and yes... I tried that and it works. THANKS!!!! Now rock'n the ableton :lol: :woohoo:
