Connecting 2 XLR AES/EBU cables together?
Nibiru
Post by Nibiru »
Hey all!
This is probably a really dumb question, but I need to know, and Google isn't the all knowing quite just yet.
Question: Can I connect 2 XLR AES/EBU cables together for the purpose of adding length, without any problems? Like weird digi artifacts or errors? Connecting the AES output of a Rosetta 200 to a MiniDAC.
Mac Mini M2 Pro - 16gb RAM - 500gb SSD | Apollo Twin Duo MkII | UAD Satellite x 2 (thunderbolt) | UAD plugins | Dell 2721QS Monitor | PMC Result 6 | DP 11.22 | Ableton | Luna
billf
Re: Connecting 2 XLR AES/EBU cables together?
Post by billf »
This might point you in the right direction:
http://www.gearslutz.com/board/high-end ... s-ebu.html
Nibiru
Post by Nibiru »
Thanks for the link. I appreciate it. However, it's not what I was asking. I should have been more clear.
I have two aes/ebu cables, which are both xlr, as they usually are. All I'm curious about is, whether I can connect the two of them to double the length, so I can use my MiniDAC for monitoring the Rosetta 200.
Thanks again!
Should be fine. Try it and see!
Works great in the analog realm for audio. One of the things I love about XLR connectors.
If crosstalk is an issue, then no. If not, then yes.
Crosstalk is the limiting factor with most digital cable length and configurations.
Nibiru
Post by Nibiru »
Interesting. I wouldn't think crosstalk to be an issue with digital cables. Thanks for the tips guys! Gonna give it a shot in a couple hours.
Nibiru
Post by Nibiru »
Tried it out. Works fine as far as I can tell. Thanks guys!
